get entity inside an xref given a point
Message 1 of 11
hi. is there any way to get the entity inside an xref given a point? im using vb.net thanks... Edited by: a7v1n on Apr 8, 2010 6:16 AM
Replies (10)
Message 2 of 11
_gile
Look at the NonInteractivePickPoint and UseNonInteractivePickPoint properties of the PromptNestedEntityOptions class.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 11
could you post some code pls? Thanks...
Message 4 of 11
_gile
Here's a C# sample
{code}private ObjectId GetNestedEntityByPoint(Point3d pt)
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
PromptNestedEntityOptions pneo = new PromptNestedEntityOptions("");
pneo.NonInteractivePickPoint = pt;
pneo.UseNonInteractivePickPoint = true;
PromptNestedEntityResult pner = ed.GetNestedEntity(pneo);
return pner.ObjectId;
}{code}
Gilles Chanteau
GileCAD
GitHub
Message 5 of 11
Help needed - Using the above code, when a point is selected in the black area on the drawing which means nothing is selected, the autocad keeps running infinitely in a loop like thing.
Is there a way to check when there is no selection made for a nested entity. Like when  nothing is selected do something.
I am using vb.net
Message 6 of 11
I have or seen something similar. When I get more time I will try to find it
For now this goes in the oppisite direction but might help.
The basic idea is when you are in paperspace and notice the xref is missing something or you want to add something. Instead of opening the xref or switching to model or editing in place the xref. You can just draw on top of the viewport then send it to the xref just as it appears.
Here is the link and alot of other great info and users http://www.theswamp.org/index.php?topic=34590.0
Message 7 of 11
thanks for the reply..
But I want to check if the selected point is on a nested entity not an entity.
For entity we can do addallowedclass(viewport) but how can we do something similar to that for a nested entity.?
i have the code i am using to get nested entity at selected point.
Dim pneo As PromptNestedEntityOptions
pneo =NewPromptNestedEntityOptions("")
pneo.NonInteractivePickPoint = selectedpoint
 pneo.UseNonInteractivePickPoint =True
Dim psubent As Entity = acTrans.GetObject(acDoc.Editor.GetNestedEntity(pneo).ObjectId, OpenMode.ForRead)
it hangs up in the above line where i am getting the objectid.
anything i am doing wrong?
Message 8 of 11
kerry_w_brown
What is the owner of the entity ?? ... may help decide
ie is the container BlockTable ModelSpace, Paperspace or a block
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 9 of 11
Thanks for the reply..
I am unable to get the owner ID of the nested entity. Since, it hangs up at getting the object ID itself, it does not go till the point I am able to get the nested entity.
Please, find my whole code is as below:
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
 Dim acCurDb As Database = acDoc.Database
While (True)
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
' Open the Block table record for read
  Dim acBlkTbl As BlockTable
 acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
 '' Open the Block table record Model space for write
  Dim acBlkTblRec As BlockTableRecord
 acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
 Application.SetSystemVariable("OSMODE", 512)
 Dim acnsprompt As PromptPointResult = acDoc.Editor.GetPoint(vbCrLf & "Select APN or <exit>: ")
If acnsprompt.Status = PromptStatus.OK And Not IsNothing(acnsprompt.Value) Then
 pneo =New PromptNestedEntityOptions("")
 pneo.NonInteractivePickPoint = acnsprompt.Value
 pneo.AllowNone =True
 If acDoc.Editor.GetNestedEntity(pneo).ObjectId = ObjectId.Null Or Not IsNothing(acDoc.Editor.GetNestedEntity(pneo).ObjectId) Or Not IsDBNull(acDoc.Editor.GetNestedEntity(pneo).ObjectId) Then
 Dim psubent As Entity = acTrans.GetObject(acDoc.Editor.GetNestedEntity(pneo).ObjectId,OpenMode.ForRead)
If psubent.GetRXClass.Name.ToString = "AcDbText" Then
 If psubent.Layer.Contains("APN") Then
Dim txt As DBText = DirectCast(psubent, Entity)
 psubent.Dispose()
 pneo =Nothing
end if
end using
end while
Message 10 of 11
Please see the below modified code is suitable for you. Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database While (True) Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite) Application.SetSystemVariable("OSMODE", 512) Dim prent As PromptEntityOptions = New PromptEntityOptions("Specify Entity:") prent.SetRejectMessage("Only BlockReferences Allowed!") prent.AddAllowedClass(GetType(BlockReference), True) Dim rsent As PromptEntityResult = acDoc.Editor.GetEntity(prent) If Not rsent.Status = PromptStatus.OK Then Return Dim pneo As PromptNestedEntityOptions pneo = New PromptNestedEntityOptions("") pneo.NonInteractivePickPoint = rsent.PickedPoint pneo.UseNonInteractivePickPoint = True pneo.AllowNone = True If Not acDoc.Editor.GetNestedEntity(pneo).ObjectId = ObjectId.Null Or IsNothing(acDoc.Editor.GetNestedEntity(pneo).ObjectId) Or IsDBNull(acDoc.Editor.GetNestedEntity(pneo).ObjectId) Then Dim psubent As Entity = acTrans.GetObject(acDoc.Editor.GetNestedEntity(pneo).ObjectId, OpenMode.ForRead) If psubent.GetRXClass.Name.ToString = "AcDbText" Then If psubent.Layer.Contains("APN") Then Dim txt As DBText = DirectCast(psubent, Entity) End If End If psubent.Dispose() End If pneo = Nothing End Using End While
Message 11 of 11
