Get All Objects Within Extents Through Database
jschierenbeck
jschierenbeck
I want to be able to select all objects within a two points on a drawing (a window selection).
However, I want to be able to achieve this through a database and not through PromptSelectionResult, since the drawing will be closed.
Basically, something like this
PromptSelectionResult prRes = AcEnv.ed.SelectWindow(dwgpt1, dwgpt2);
ObjectId[] objIdArray = prRes.Value.GetObjectIds();
But on a closed drawing.
Is this possible?
jschierenbeck
This is a solution I found for this, but it seems like there should be an easier way.
I ended up iterating though all the objects in the drawing and comparing the extents
var blockTable = (BlockTable)acTrans.GetObject(database.BlockTableId, OpenMode.ForRead);
foreach (var btrId in blockTable)
      var btr = (BlockTableRecord)acTrans.GetObject(btrId, OpenMode.ForRead);
      if(btr.IsLayout)
         foreach(var id in btr)
            var ent = (Entity)acTrans.GetObject(id, OpenMode.ForRead);
         try
            var ext = ent.GeometricExtents;
            if(ext.MaxPoint.X <= extents.MaxPoint.X && ext.MaxPoint.Y <= extents.MaxPoint.Y && ext.MinPoint.X >=         extents.MinPoint.X && ext.MinPoint.Y >= extents.MinPoint.Y)
               foundBlocksList.Add(ent.Id);
         catch (Exception ex)
            if (!ex.Message.Contains("eNullExtents"))
            throw;
