Get all entities inside a blockreference
哀家爆
Message 1 of 16
哀家爆
Hi, I've had some problems trying to get all entities inside a blockreference. As the following pic, there are 4 lines and another blockreference inside a blockreference.
var entities = new List<Entity>();
var objects = new DBObjectCollection();
block.Explode(objects);
the objects returns me only 4 lines but no blockreference.
What is amazing is that when I mirror the whole blockreference and execute the code again, I can get 4 lines and a blockreference from the mirrored blockreference.
Is there sth wrong with my code, or is there a better way to get all entities inside a blockreference.
Thanks.
Replies (15)
Message 2 of 16
_gile
A block reference (BlockReference) does not contain entities, it is just a reference to a block definition (BlockTableRecord) which does contain entities.
You can get the ObjectId of the block definition using the BlockReference.BlockTableRecord property, open the BlockTablerecord for read and iterate through its contents.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 16
哀家爆
Thanks for your answer.
How am I supposed to understand that we can obtain the DBObjectCollection by using :
blockReference.Explode();
And I did get what I wanted by using the 'Explode()' method in most cases.
In the example above, the blockReference consists of four lines and another blockReference. In general, I can get what I want. Just this time I do not know what reason cause the 'Explode()' method to lose a blockReference.
Message 4 of 16
hosneyalaa
Hi
Please look at this is
https://forums.autodesk.com/t5/net/how-to-get-poin-center-of-circle-in-block/m-p/10354555
Change this
id.ObjectClass.DxfName.ToUpper() == "CIRCLE")
To
id.ObjectClass.DxfName.ToUpper() == "line")
Message 5 of 16
哀家爆
Hi, _gile
var blockTableRecordId = block.BlockTableRecord;
BlockTableRecord blockTableRecord = null;
using (var ts = block.Database.TransactionManager.StartTransaction())
    blockTableRecord = ts.GetObject(blockTableRecordId, OpenMode.ForRead) as BlockTableRecord;
    foreach (var id in blockTableRecord)
        var ent = (Entity)ts.GetObject(id, OpenMode.ForRead);
        ent.TransformBy(block.BlockTransform);
        entities.Add(ent);
Now I use your way to get all entities from a blockreference (throuth the blocktablerecord), and get the correct result.
But the following statement :
throw a exception :
Autodesk.AutoCAD.Runtime.Exception:“eMissingSymbolTableRec”
What is wrong with this?
Best regards!~
Message 6 of 16
哀家爆
Hi, _gile
        entities.Add(ent);
throw a exception : Autodesk.AutoCAD.Runtime.Exception:“eMissingSymbolTableRec”
What is wrong with this? Best regards!~
Message 7 of 16
_gile
I was just trying to reply to your question : "is there a better way to get all entities inside a blockreference."
        private static IEnumerable<Entity> GetEntitiesWithinBlock(BlockReference br) =>
            ((BlockTableRecord)br.BlockTableRecord.GetObject(OpenMode.ForRead))
            .Cast<ObjectId>()
            .Select(id => (Entity)id.GetObject(OpenMode.ForRead));
Gilles Chanteau
GileCAD
GitHub
Message 8 of 16
_gile
You should not tranform the entity within the block definition, you should clone it and transform the clone.
            var btr = (BlockTableRecord)br.BlockTableRecord.GetObject(OpenMode.ForRead);
            var ids = new ObjectIdCollection(btr.Cast<ObjectId>().ToArray());
            var mapping = new IdMapping();
            br.Database.DeepCloneObjects(ids, br.OwnerId, mapping, false);
            foreach (IdPair pair in mapping)
                if (pair.IsCloned && pair.IsPrimary)
                    var entity = (Entity)pair.Value.GetObject(OpenMode.ForWrite);
                    entity.TransformBy(br.BlockTransform);
                    yield return entity;
Gilles Chanteau
GileCAD
GitHub
Message 9 of 16
哀家爆
thanks a lot,I will try again.
Message 10 of 16
哀家爆
What if I want to get all entities recursively?
public static void GetEntitiesWithinBlock(BlockReference br, Document doc, ref List<Entity> entities)
            using (var ts = doc.Database.TransactionManager.StartTransaction())
                var asd = br.BlockTransform;
                        var entity = (Entity)ts.GetObject(pair.Value, OpenMode.ForWrite);
                        if (entity is BlockReference blockReference)
                            GetEntitiesWithinBlock(blockReference, doc, ref entities);
                        else
                            entities.Add(entity);
And the statement: entity.TransformBy(br.BlockTransform); throw a new exception: eCannotScaleNonUniformly.
Thanks a lot!
Message 11 of 16
_gile
                    if (entity is BlockReference)
                        foreach (var ent in GetEntitiesWithinBlock((BlockReference)entity))
                            yield return ent;
                        entity.Erase();
                    else
Gilles Chanteau
GileCAD
GitHub
Message 12 of 16
哀家爆
When the entity is BlockReference,
throw the exception: eMissingSymbolTableRec.
It seems that AutoCAD doesn't allow us to transform a blockReference which is within another blockReference .
Message 13 of 16
_gile
We do not transform the block reference which is within the block definition, we transform the clone.
The upper code works for me.
Gilles Chanteau
GileCAD
GitHub
Message 14 of 16
哀家爆
Could you please help me to test the attached dwg file.
I've no idea why the exception happens in my test.
Thank you very much !
Message 15 of 16
_gile
In the "blocktest"drawing, the block is not uniformy scaled.
Gilles Chanteau
GileCAD
GitHub
Message 16 of 16
NSJamieLiu
Community Visitor
Community Visitor
hi there: I am facing the same problem. I want to transform inner objects within a non uniformy scaled blockrefernce. So what should I do if the blockrefernce is not uniform scaled?
all the best
