geometric extents in UCS
I want to draw a frame around text, using GeometricExtents property works good for texts, that are not rotated compared to WCS, but i can't figure out the way to do it for rotated texts.
Paulio
Have you tried using
Autodesk.AutoCAD.Internal.Utils.GetTextExtents
This gives you a point2d of the extents of the text which you can then use to figure out where to draw your frame (i.e. by adding this point onto the location of your text).
Kind of like this
Using trans As Transaction = db.TransactionManager.StartTransaction
                Dim mTxt As MText = trans.GetObject(oid, OpenMode.ForRead)
                Dim pext As Point2d = Autodesk.AutoCAD.Internal.Utils.GetTextExtents(db.TextStyleTableId, mTxt.Contents, 200)
                Dim pline As New Polyline
                pline.AddVertexAt(0, New Point2d(mTxt.Location.X, mTxt.Location.Y), 0, 0, 0)
                pline.AddVertexAt(1, New Point2d(mTxt.Location.X + pext.X, mTxt.Location.Y), 0, 0, 0)
                pline.AddVertexAt(2, New Point2d(mTxt.Location.X + pext.X, mTxt.Location.Y - pext.Y), 0, 0, 0)
                pline.AddVertexAt(3, New Point2d(mTxt.Location.X, mTxt.Location.Y - pext.Y), 0, 0, 0)
                pline.Closed = True
                Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
                Dim btr As BlockTableRecord = trans.GetObject(bt.Item(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                btr.AppendEntity(pline)
                trans.AddNewlyCreatedDBObject(pline, True)
                trans.Commit()
            End Using
 It seems to work ok whether in world or ucs if the angle of the text is 0. If the text itself is rotated then you'll need to transform your frame to rotate it to the same angle as the text.
It won't work for text that's rotated in 3d though.
It will also only work in 2010 as I don't think the ...Internal.Utils.GetTextExtents is available prior to that.
HTH
thank you, i will test it and post result, i work in 2011, so it should be OK
hm, the edit option has limited time, so i have to do new post, sorry
it works great, BUT
i modified your code slightly, because i use it for single line text and that doesn't use Location, but Position property
but this property represents the point "on the line", so for text with characters that have "underline" part, the frame is shifted a little up
