Generating dynamic color coded floor plans based on database values
My company is looking to migrate from third party facilities management software to build in house. The key component would be the ability to color code seats/rooms on our floor plans (on demand through an internally built GUI,) based on a variety of data in the database.
Before I start investigating the internal costs to do this, I would like to know if it's even possible. I believe at one time, this type of relationship was a proprietary relationship between the CAFM software companies and  Autodesk.
norman.yuan
Since you did not provide more details about what "color coded floor plan" mean, I assume it is in general a CAD process to draw different things (room, furniture, whatever...) in different color (or on different layers so the color is determined by layer) based on data outside AutoCAD. Because this is AutoCAD programming forum, I also assume you are more interested in if it can be done with AutoCAD programming.
Yes, it surely can be done, easily, or not so easily, depending on the scope. Basically, the entire thing would be:
1. Manage the data outside AutoCAD. The data would typically stored in database (or simply file(s) if the amount of data is small and data model is very simple).
2. AutoCAD access the data, mostly read-access, but maybe, write-access to some data is required.
3. AutoCAD draws somethings according to data obtained.
Depending on you programming knowledge: if you know basic AutoCAD programming, you can do 3 fairly easily; if you have database programming knowledge, you would be able to do 1 in some way, and know how to expose the data to other application (AutoCAD): either let AutoCAD directly connect to the database, or expose the data via some kind of services (web services, for example, in your intranet, or in the cloud). As for 2, if you are fairly experienced programmer and know what "interface" is, you would do the AutoCAD data access layer in a very generic fashion, so the data access is not tightly tied to certain data source, so that regardless where the data source is or what type the data source is, AutoCAD always use the same set of function calls to get data, and draws things according to the data.
To take on this task, whoever designs/develops the solution, both programming experiences of both AutoCAD and data access from database/services are required, which is a quite common work done by many AutoCAD programmers, who may or may not frequent visitor of this forum. You may also find existing third party applications that have already done the same, or very similar thing. Those third party app developers may be interested in custom their existing app to accommodate your specific needs easier (than reinventing the wheel again).
So, yes, it is very possible/doable, as long as you have the right resources (the programmer(s) with know-how).
Norman Yuan
Drive CAD With Code
Thank you for the answer. I apologize for not being more clear.
I need to generate on demand drawings that color code polylines (rooms on a drawing) based on values in the database. Basically, I need bi-directional communication between the database and the drawing, so the code can generate a drawing on demand through the GUI.
This ability exists with a third-party software, but I don't believe that the bi-directional communication is available just with Autocad out-of-box. As far as I know, without the third party software, Autocad can query a database, but the database cannot query Autocad.
norman.yuan
This is where AutoCAD programming comes in. Without knowing much about your business requirements, I can only say that it is very likely doable, as long as you have developers who have the know-how: driving AutoCAD, or its cloud engine (Forge automation) automatically, semi-automatically, or manually by CAD user to do something with external data is very common AutoCAD programming task.
Norman Yuan
Drive CAD With Code
hgasty1001
I agree with Norman in that the task seem very doable with AutoCAD programming, but you can also check an Autodesk product that have tools aimed to the same result, AutoCAD Map 3D or Map 3D Toolset. Map (as we call it) has tools for connect object with databases, query multiple drawings (without opening), create thematic maps (based on attributes or database fields, etc), create reports, etc. Map is a GIS oriented product, but if you think a facility as a little territory you can made use of the generics of GIS tools in a more geographic reduced environment as a facility or group of them. Even if Map by itself is not sufficient, you can also use the Map 3D API + AutoCAD API to accomplish the task. Finally I think that AutoCAD + Map 3D toolset it's a better platform for your task than only AutoCAD.
Gaton Nunez
