Form freezes after showing, hiding and re-displaying
williamdepadua
williamdepadua
Hello, follow the schematic code.
<Autodesk.autocad.rutime.commandmethod("teste")>_
Public Sub open()
ShowModalDialog(Myform)
End Sub
Private Sub btClick()
Me.hide()
If ...... then
Exit sub
End if
End sub
I view my form in a restricted way, click on a button that hides the form using myform.hide, and ask me to select an entity. If I deselect it, it should display the form again. This works the first time I cancel, but if I do it one more time, the form freezes. The sequence would be to display form, click button, esc, click button, and esc. Freezes.
Norman_Yuan
It is known issue that calling Form.Hide() with a modal form in AutoCAD plugin is problematic.
When user needs to interact with AutoCAD editor from a modal UI, as you intend to do, you should use EditorUserInteraction object, by calling
var editor=Application.DocumentManager.MdiActiveDocument.Editor;
// This hide the modal form automatically
using (edit.StartUserInteraction([modalForm]))
   // Do selection in AutoCAD editor here
   // When the using{...} ends, the modal form shows back automatically
Norman Yuan
Drive CAD With Code
williamdepadua
Great, it worked. Thank you
