Form Button Object reference not set
ERGCONSULT
ERGCONSULT
I have written some code to create a project file based on information on a form the original code was VB6 and sense I upgraded it to VB10  when I click the cmdCreat button I get
System.NullReferenceException: Object reference not set to an instance of an object.
at CreateProjII.frmCreateProj.cmdCreate_Click(Object sender, EventArgs e)
Here is the form code
Option Explicit On
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Imports System
Imports System.IO
Imports System.Xml
Imports System.Xml.Linq
Public Class frmCreateProj
Private Sub cmdCancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdCancel.Click
Me.Close()
End Sub
Public Sub cmdCreate_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdCreate.Click
Dim oApp As Inventor.Application
oApp = ThisApplication
Dim oDocs As Inventor.Documents
oDocs = oApp.Documents
Dim filename As String
If txtFileNum.Text = "" Then
filename = txtProj.Text & "_" & txtComp.Text
Else
filename = txtFileNum.Text
Dim IpjName As String
IpjName = txtIpjName.Text
Dim projnum As String
projnum = txtProj.Text
Dim compname As String
compname = txtComp.Text
Dim Title As String
Title = txtTitle.Text
Dim vendor As String
vendor = "Gerbcon"
'create project folders
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename)
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\Templates")
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\Content Center Files")
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\Assemblies")
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\Parts")
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\Drawings")
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\SentItems")
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\Quotes")
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\Imported components")
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\Notes")
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\Electrical")
My.Computer.FileSystem.CreateDirectory("H:\Current Engineering\" & filename & "\Drawings" \ " txtProj.txt-1")
'Copy the Iparts folder and rename it Standard Parts
My.Computer.FileSystem.CopyDirectory("C:\NewProject\Iparts2010", "H:\Current Engineering\" & filename & "\StandardParts")
My.Computer.FileSystem.CopyDirectory("C:\NewProject\BOM", "H:\Current Engineering\" & filename & "\BOMS")
'generate ProjInfo.xml inside Templates folder
Dim B As XElement = _
<Project>
<FileNumber><%= filename %></FileNumber>
<SONumber><%= projnum %></SONumber>
<Customer><%= compname %></Customer>
<JobTitle><%= Title %></JobTitle>
</Project>
B.Add(<AdditionalSOs>
<AddSO1><%= projnum %></AddSO1>
</AdditionalSOs>) 'create element to throw additional SO numbers into starting with current SO
B.Add(<AdditionalJobTitles>
<AddJobTitle1><%= Title %></AddJobTitle1>
</AdditionalJobTitles>) 'create element to throw additional Titles into starting with current title
B.Save("H:\Current Engineering\" & filename & "\Templates\ProjInfo.xml")
'Finally, copy and modify new .ipj file (project file)
My.Computer.FileSystem.CopyFile("C:\NewProject\Temp2017.ipj", "H:\Current Engineering\" & filename & "\" & IpjName & ".ipj")
MsgBox("PROJECT BUILD COMPLETE", vbOKOnly)
Me.Close()
End Sub
End Class
E Gerber
BKSpurgeon
Hi there
When ever you see something like this - it means that the pertinent reference (in this case cmdCreat) is not pointing to an actual button/or object.
Where have you created the button? Where is your UI code?
You need to instantiate the button somewhere in your code otherwise you will get the above error.
e.g.
System.Windows.Forms.Button cmdCreat  = new System.Windows.Forms.Button();
ERGCONSULT
First off Thank you for taking the time to look at this,
There is nothing in the project anywhere resembling your comments and I believe all the UI is located in the StandardAddInServer.vb which is attached.
My apologies if I am not clear I am fairly new at this and I have only been maintaining the code for the past few years,
E Gerber
ActivistInvestor
Your button click event handler where the exception is being thrown references variables that appear nowhere in the code you posted.
You are expecting others here to tell you what's wrong with code that you didn't post.
Try running your code in the debugger and step through the code in the event handler to find out what variable has not been initialized.
ERGCONSULT
I have attached the complete project in the hopes that you can point out what is missing, Here is a how I went about creating this project, I created a new project using the  2018 wizard I then added the old cod and form to the project using the add existing item feature, I then modified the code to display the button on the UI to open the form, Which works fine. If I click the cancel button the form closes without error,
I hope this is more useful than my previous posts
Thank you in advance for taking the time to guide me
E Gerber
ERGCONSULT
Please disregard my previous post I attached the original project not the  current one
Current project attached to this post
E Gerber
ActivistInvestor
Your project is an Inventor plug-in.  This is the AutoCAD .NET programming forum.
There is a forum for Inventor customization, which is where you should be seeking help.
Regardless of what kind of project it is, to find out where the problem is, You have to
run the code in the debugger. Ask in the above forum how to go about debugging
Inventor plug-ins, if you're not sure how to do that.
