find if ExternalReferences Is Nested Reference
Danny.isr
Danny.isr
StephenPreston
You could try looking at the XrefGraph for the drawing - see Database.GetHostDwgXrefGraph(). Here's a blog post that shows how to use that function, although not for the same reason you want it - http://through-the-interface.typepad.com/through_the_interface/2009/05/importing-autocad-layers-from...
Cheers,
Stephen Preston
Autodesk Developer Network
First You have to realize how does the xrefs works. The external references are placed in block table as a block table records. They are in a flat structure (opposite to tree structure) it means if we have attached drawing which have another external references, those references will be in top level in block table or they will be entity in model space.
Here is explaination:
MainDrawing.dwg
|---AttachedDrawing.dwg
||---AnotherAttachedDrawing.dwg
|---AnotherDrawing.dwg
BlockTable in MainDrawing will look like this:
MainDrawing-BlockTable
-AnotherDrawing.dwg
-ModelSpace
-AnotherDrawing.dwg
- ... another block talbe records
We can check if attached drawing is external reference by property IsXref.
Dim AcadDocument As AcadDocument = Application.DocumentManager.MdiActiveDocument.AcadDocument
For Each block As AcadBlock In AcadDocument.Blocks
    If block.IsXRef OrElse block.ObjectID = AcadDrawing.ModelSpace.ObjectID Then
        ' Your code here
    End If
Next
If drawing is xref we can get its path, and open that document in background.
Dim drawing As Database = New Database(False, True)
drawing.ReadDwgFile(pathToReference, FileOpenMode.OpenForReadAndAllShare, True, Nothing)
You can search for each references in opened drawing and check if there are external references by Property IsFromExternalReference. If drawing contain external reference it means that it's nested reference.
Unfortunatelly the best way for doing this is recursion because nested references can appear on different level. The worst information is in some case You can have the same reference on different lvl or duplicated references... . It's long and hard way...
Dim blockTable As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
For Each blockTableRecId As ObjectId In blockTable
Dim blockTableRec = tr.GetObject(blockTableRecId, OpenMode.ForRead)
If blockTableRec.IsFromExternalReference
' Is nested reference
Danny.isr
Thank you
Dim bt As Autodesk.AutoCAD.DatabaseServices.BlockTable
 Dim btr As BlockTableRecord
Dim blockId As ObjectId
 Dim iter As IEnumerator
Dim xg As XrefGraph = db.GetHostDwgXrefGraph(False)
 bt = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
 iter = bt.GetEnumerator() Do While iter.MoveNext()
 blockId = iter.Current btr = trans.GetObject(blockId, OpenMode.ForWrite)
If btr.IsFromExternalReference Then
        If Not xg.GetXrefNode(btr.Name).IsNested Then
                btr.IsUnloaded = True
                If btr.IsUnloaded = True Then
                      Dim aa As New SiWeb.BaseFileVersion(btr.PathName)
                End If
         End If
End If
