find attribute definition value in one shot
hi,
I have a block definition which has 15 attribute definitions in my drawing. I need to know one of the attribute definition value of a block reference. In order to do that I have to loop all the attrribute collection of my block reference and load the object by its ID . this way, I have a performance problem. is there an easy way to find a block's attdef in one shot?
here is my method:
public String GetAttDefOfABlock(BlockReference br,String attributeName)
String returnValue = "";
foreach (ObjectId id in br.AttributeCollection)
AttributeReference attRef = (AttributeReference)HandleToBlockReference(id.Handle.ToString()); // this line loads the object to get its value
if (attRef.Tag.ToString() == attributeName)
returnValue = attRef.TextString;
break;
return returnValue;
_gile
AFAIK, you can't get an attribute reference "in one shot". But I never notice any "performance issue" even with much more attributes than 15.
I don't know what doe's the HandleToBlockReference() method but it's perhaps the cause of the "performance issue".
Try this way (assuming the method is called from within a transaction):
        public string GetAttValue(BlockReference br, string attributeTag)
            string returnValue = "";
                AttributeReference attRef = (AttributeReference)id.GetObject(OpenMode.ForRead);
                if (attRef.Tag == attributeTag)
                    break;
            return returnValue;
PS: the value you want has nothing to do with an attribute definition, it's the value of the attribute reference. An AttributeDefinition typically owns to a block definition (BlockTableRecord).
Gilles Chanteau
GileCAD
GitHub
