EXTRACT LAT LONG
EXTRACT LAT LONG
vjohnson8HQZZ
EXTRACT LAT LONG
vjohnson8HQZZ
I have this following code which extracts x,y coordinates of a Block in the model space.
Could someone please help to know how I can extract the Lat Long of these coordinates, given that Geolocation is already set up in the drawing.
Thanks in advance.
public class Class1
    [CommandMethod("TEST")]
    public static void Test()
        var doc = Application.DocumentManager.MdiActiveDocument;
        var db = doc.Database;
        var ed = doc.Editor;
        var peo = new PromptEntityOptions("\nSelect Block A: ");
        peo.SetRejectMessage("\nSelected object is not a block.");
        peo.AddAllowedClass(typeof(BlockReference), true);
        var per = ed.GetEntity(peo);
        if (per.Status != PromptStatus.OK)
            return;
        using (var tr = db.TransactionManager.StartTransaction())
            var br = (BlockReference)tr.GetObject(per.ObjectId, OpenMode.ForRead);
            var btr = (BlockTableRecord)tr.GetObject(br.BlockTableRecord, OpenMode.ForRead);
            foreach (ObjectId id in btr)
                if (id.ObjectClass.Name == "AcDbBlockReference")
                    var nested = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                    var position = nested.Position.TransformBy(br.BlockTransform);
                    ed.WriteMessage($"\nPosition of block '{nested.Name}': {position}");
                    break;
            tr.Commit();
Norman_Yuan
			var geoData=(GeoLocationData)tr.GetObject(db.GeoDataObject, OpenMode.ForRead);
					var lonlatInfo=geoData.TransformToLonLatAlt(position);
					ed.WriteMessage($"\Long: {lonlatInfo.Longitude}, Latitude: {lonlatInfo.Latitude}");
                    break;
            tr.Commit();
Norman Yuan
Drive CAD With Code
Gepaha
For me lonlatInfo is returned as Point3d, which is in geographic coordinates. There is no option to get the values ​​in lonlatInfo.Longitude and lonlatInfo.Latitude format.
Point3d geoPt = geoData.TransformToLonLatAlt(wcsPt);
Only GeoDataLonLatAltInfo contains Latitude, Longitude.
GeoDataLonLatAltInfo geoPt1 = geoData.TransformToLonLatAlt(geoPt.X, geoPt.Y, geoPt.Z);
Norman_Yuan
@Gepaha
You are right: with the GeoLocation's API, it is 2-step call the 2 overloaded TransformToLonLatAlt() methods with original drawing's Point3d to eventually get Lon/Lat. I confused it with a custom extension method I used, which combines the 2 steps into one.
Norman Yuan
Drive CAD With Code
vjohnson8HQZZ
Thank you so much, @Norman_Yuan , @Gepaha
The code you provide works well.
