Exporting multiple blocks in one dwg to having them as individual dwgs
there are some blocks in one dwg file,how can i exporting them as individual dwgs,
please show me the code,if you like,
thank you
This is some cun&paste from old code, so forgive me if I left some unreferenced functions, but you should be able to overcome them:
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Windows;
using WIN = System.Windows.Forms;
[assembly: CommandClass(typeof(WorkshopNET.csBlockTools))]
namespace WorkshopNET
    public class csBlockTools
       [CommandMethod("export_blocks", CommandFlags.UsePickSet | CommandFlags.Redraw | CommandFlags.Modal)]
        static public void comsal_export_blocks()
            if (Application.DocumentManager.Count == 0) return;
            // shorter references
            Document doc = Application.DocumentManager.MdiActiveDocument;
            if (doc == null) return;
            DocumentLock docLock = doc.LockDocument(DocumentLockMode.AutoWrite, "export_blocks", "export_blocks", true);
            Database dwg = doc.Database;
            Editor ed = doc.Editor;
            // ask to select blocks to export, it works also with pre-selected entities
            PromptSelectionResult selectionRes = ed.SelectImplied();
            // Check for pre-selected entities...
            if (selectionRes.Status == PromptStatus.Error)
                // ... otherwise ask for selection
                PromptSelectionOptions opt_sel = new PromptSelectionOptions();
                opt_sel.MessageForAdding = "\nSelect blocks to export:";
                opt_sel.MessageForRemoval = "\nUnselect blocks:";
                TypedValue[] tvsb = new TypedValue[1]
                    new TypedValue((int)DxfCode.Start, "INSERT")
                SelectionFilter sf = new SelectionFilter(tvsb);
                selectionRes = ed.GetSelection(opt_sel, sf);
                if (selectionRes.Status != PromptStatus.OK) return;     // Exit if abort
            else
                // Clean pre-selection
                ed.SetImpliedSelection(new ObjectId[0]);
            if (selectionRes.Value.Count == 0) return;
            // Ask for target directory
            // as default use same folder of the current document
            DirectoryInfo d = new DirectoryInfo(Path.GetDirectoryName(doc.Name));
            // use windows standard dialog
            WIN.FolderBrowserDialog fbd = new WIN.FolderBrowserDialog();
            fbd.ShowNewFolderButton = true;
            fbd.SelectedPath = d.FullName;
            if (fbd.ShowDialog() == System.Windows.Forms.DialogResult.OK)
                String szBaseFolder = fbd.SelectedPath + "\\";     // shorter reference
                Transaction tr = dwg.TransactionManager.StartTransaction();
                try
                    // cycle on blocks and export them
                    foreach (SelectedObject ss in selectionRes.Value)
                        DBObject dbo = tr.GetObject(ss.ObjectId, OpenMode.ForRead);
                        if (dbo is BlockReference && !dbo.IsErased)
                            BlockReference br = dbo as BlockReference;
                            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(br.IsDynamicBlock ? br.DynamicBlockTableRecord : br.BlockTableRecord, OpenMode.ForRead);
                            if ((btr.Name.Length > 0) && (!btr.Name.Contains("*")))
                                String szNewName = szBaseFolder + btr.Name + @".dwg";
                                // build a new database and save it as WBLOCK()
                                Database newdb = new Database(false, true);
                                newdb = doc.Database.Wblock(btr.ObjectId);
                                newdb.SaveAs(szNewName, DwgVersion.Current);
                                newdb.Dispose();
                    tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage("\n*** unexpected error : " + ex.Message + " ***");
                finally
                    tr.Dispose();
            ed.WriteMessage("\n");
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
thank you very much,i'll test it.thank you your quick reply.
