Explode results and selection results differ on computers
h3nrik
h3nrik
Hi
Am at a loss at the moment (again, as usual..)
Same DWG located on a network share
Using this method (update since first post) to explode within a selection
        public static bool WithinSelection(SelectionSet selection) {
            Document document = Application.DocumentManager.MdiActiveDocument;
            Editor editor = Application.DocumentManager.MdiActiveDocument.Editor;
            editor.WriteMessage("\nAtiveViewPortId: " + editor.ActiveViewportId + ", CurrentViewportObjectId: " + editor.CurrentViewportObjectId);
            var somthingExploded = false;
            using (Transaction transaction = document.Database.TransactionManager.StartTransaction()) {
                try {
                    BlockTable blockTable = transaction.GetObject(document.Database.BlockTableId, OpenMode.ForRead) as BlockTable;
                    BlockTableRecord blockTableRecord = transaction.GetObject(blockTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                    foreach (ObjectId objectId in selection.GetObjectIds()) {
                        Entity selectedEntity = transaction.GetObject(objectId, OpenMode.ForRead) as Entity;
                        if (selectedEntity == null) {
                            editor.WriteMessage("\nNull entity with " + objectId.ToString());
                            continue;
                        if (selectedEntity is BlockReference selectedBlockReference) {
                            editor.WriteMessage("\nSelected handle:" + selectedEntity.Id.Handle + ", Name: " + selectedBlockReference.Name + ", BlockName:" + selectedBlockReference.BlockName);
                            using (DBObjectCollection resultOfExplode = new DBObjectCollection()) {
                                try {
                                    selectedEntity.Explode(resultOfExplode);
                                    foreach (DBObject obj in resultOfExplode) {
                                        Entity explodedEntity = obj as Entity;
                                        blockTableRecord.AppendEntity(explodedEntity);
                                        transaction.AddNewlyCreatedDBObject(explodedEntity, true);
                                        //editor.WriteMessage("\nAdding exploded into transaction " + explodedEntity.Id.Handle + " - " + explodedEntity);
                                    if (resultOfExplode.Count > 0) {
                                        editor.WriteMessage("\nExploded " + resultOfExplode.Count.ToString());
                                        selectedEntity.UpgradeOpen();
                                        selectedEntity.Erase(true);
                                        somthingExploded = true;
                                    } else {
                                        editor.WriteMessage("\nNothing exploded");
                                } catch (Autodesk.AutoCAD.Runtime.Exception ex) {
                                    editor.WriteMessage("\nError 1 " + ex.Message + " " + ex.StackTrace + "\nEntity: " + selectedEntity);
                        } else {
                            editor.WriteMessage("\nSelected handle is not a block:" + selectedEntity.Id.Handle + " - " + selectedEntity);
                            continue;
                    editor.WriteMessage("\nCommit transactoin");
                    transaction.Commit();
                    editor.WriteMessage("\nError 2 " + ex.Message + " " + ex.StackTrace);
                    transaction.Abort();
            return somthingExploded;
Called like this two times in a row with the same coordinates
var selectionResult = editor.SelectCrossingWindow(new Point3d(x1, y1, 0), new Point3d(x2, y2, 0));
            if (selectionResult.Status != PromptStatus.OK) {
                editor.WriteMessage("\nInvalid selection - " + selectionResult.Status);
                return;
            var result = Explode.WithinSelection(selectionResult.Value);
Computer 1 yields this
AtiveViewPortId: (2569554406032), CurrentViewportObjectId: (0)
Selected handle:9695, Name: PICT_OWNER, BlockName:*Model_Space
Exploded 2
Commit transactoin
Selected handle:9754, Name: BackingSheet, BlockName:*Model_Space
Exploded 325
Selected handle is not a block:974E - Autodesk.AutoCAD.DatabaseServices.Polyline2d
Commit transactoin
Computer 2
AtiveViewPortId: (1948773767824), CurrentViewportObjectId: (0)
Exploded 2
Commit transactoin
True
Invalid selection - Error
What steps can I take to try and figure out why the second explode fails on computer 2? Can I get more details as to why the selection is an Error? My best clue so far is that if I call a different CommandMethod, that will execute the same WithinSelection-method, it works but the handles on selected and exploded entities are not the same as Computer 1..
Selected handle:97CA - Autodesk.AutoCAD.DatabaseServices.BlockReference
Exploded into 325
Selected handle:97C4 - Autodesk.AutoCAD.DatabaseServices.Polyline2d
Selected is not BlockReference, skipping
Commit transactoin
norman.yuan
You did not show how the PromptSelectionResult, which is passed into the WithinSelection() method, is obtained, but it seems implying the PromptSelectionResult is returned by calling Editor.Select[Crossing]Window() method.
The issue you came across ("invalid selection") clearly indicates there is nothing selected. It is not a sound coding practice by passing PromptSelectResult as parameter to the method. You should check the PromptResult status first, and ONLY CALL the exploding method if the PromptResult.Status is OK and passing the PromptSelectionResult.Value to the method, meaning there is indeed at least one entity is selected for exploding.
It is very possible that the selecting window is not within a current view, thus the selecting was not done correctly. Every AutoCAD programmer should know that when doing selecting with window/polygon/fence by calling API (be it .NET API, COM API, or LISP) the selecting window/polygon/fence... MUST BE within current view, or the selecting would failed, or not selecting correctly.
Norman Yuan
Drive CAD With Code
h3nrik
"but it seems implying the PromptSelectionResult is returned by calling Editor.Select[Crossing]Window() method."
Yes
Ok - thanks for the correction, I will update my code to follow best practice. Hopefully it will shed some light on why different computers get different selections..*** Update is done and reflected in first post. Still same issue.
Follow up, how do I check which view I am currently trying to do the selection in? editor.ActiveViewportId?
Noticed now that one computer is running AutoCad 2019 and the other is running AutoCad Mechanical 2019 - can that be the source of the issue?
h3nrik
So I made a new test method to call the explode-method, just hard coding the coordinates
[CommandMethod("valitExplodeTest2")]
        public static void ExplodeTest2() {
            editor.WriteMessage("\nalitExplodeTest2 AtiveViewPortId: " + editor.ActiveViewportId + ", CurrentViewportObjectId: " + editor.CurrentViewportObjectId);
            var selectionResult = editor.SelectCrossingWindow(new Point3d(4000, 2000, 0), new Point3d(0, 0, 0));
                return;
            editor.WriteMessage("\n" + result);
Automatic run, calling valitExplodeTest2 two times in a row yield this
alitExplodeTest2 AtiveViewPortId: (1462350414480), CurrentViewportObjectId: (0)
WithinSelection AtiveViewPortId: (1462350414480), CurrentViewportObjectId: (0)
Exploded 2
Commit transactoin
If I then call the function myself one more time it magically works..why? 😄
Selected handle:97CA, Name: BackingSheet, BlockName:*Model_Space
Exploded 325
Selected handle is not a block:97C4 - Autodesk.AutoCAD.DatabaseServices.Polyline2d
Commit transactoin
h3nrik
Included example DWG and complete C# source code (.txt files are .cs files).
I start the process like this:
"C:\Program Files\Autodesk\AutoCAD 2019\acad.exe" /b C:\temp\acadissue\start.scr
start.scr is:
secureload 0
netload "V:\AVEVA\MACRO_LEAP-E3D\VALIT_ISO-DFLTS_2\VALISO\DWG_Extension\dev_dll\ValIT_AcadAppendBlocks.dll"
sampleReadListOfDwg "C:\temp\acadissue\_listOfDwgs.txt"
_listOfDwgs.txt is just lines with full file path to files that should be opened and processed, in this time and moment, only
C:\temp\acadissue\f-n-block.dwg
h3nrik
Starting AutoCad Mechanical with vanilla profile solved my issues
"C:\Program Files\Autodesk\AutoCAD 2023\acad.exe" /p "<<VANILLA>>" /b ...
