Exit Recursive function .net
matt.worland
Advisor Advisor
matt.worland
    ' Recursively grabs ObjectIDs of xrefs
    ' used by HandleToOID
    Private Shared Function ChildrenGet(i_root As GraphNode, i_Tx As Transaction, myHNDL As Handle, myOwnerHNDL As Handle) As ObjectId
        For o As Integer = 0 To i_root.NumOut - 1
            Dim child As XrefGraphNode = TryCast(i_root.Out(o), XrefGraphNode)
            If child.XrefStatus = XrefStatus.Resolved Then
                Dim bl As BlockTableRecord = TryCast(i_Tx.GetObject(child.BlockTableRecordId, OpenMode.ForRead), BlockTableRecord)
                If bl.Handle = myOwnerHNDL Then
                    'we found the parent object, now find myHandle
                    Dim myXrefDB As Database = bl.GetXrefDatabase(False) ' check for example on what the number means
                    Using XTrans As Transaction = myXrefDB.TransactionManager.StartTransaction
                        Try
                            Dim myEntOID As ObjectId = myXrefDB.GetObjectId(False, myHNDL, 0)
                            MsgBox(myEntOID.ObjectClass.Name & vbCr & bl.Handle.ToString & vbCr & myEntOID.ToString)
                            Return myEntOID
                        Catch myex As System.Exception
                            MsgBox(myex.Message)
                        End Try
                    End Using
                    Exit For
                Else
                    ChildrenGet(child, i_Tx, myHNDL, myOwnerHNDL)
        Next
    End Function
 Im a bit stuck on the code above.
Depending on how deep the xref nesting goes, it appears that .net will step back out of the code one level at a time.
I can hit this line with a valid ObjectId: Return myEntOID
But when I hit that point, it steps through to End Function, Like I would think it would.
Then goes back to:
Else
Is this normal .net behaviour, How do I exit the function with my value?
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
Balaji_Ram
Hi Matt,
I think this is a general behavior with any recursive function.
If you want the recursion to end, you may try using a boolean value that gets passed into the function. This will let the top level recursions to know that the value that you are interested in has been found and it no longer needs to invetigate further. If so, the function can simply return which willl make it go back one level up and this will repeat until your recursion ends.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
matt.worland
Thank you, Im just figuring out what all of the .net functions do I guess. I assumed, the RETURN would return me and exit out of the function.
Thanks again for the explanation.
