Execute CUI Ribbon Button Without Displaying Command Name in Command Prompt
santhoshr151194
santhoshr151194
I have written custom commands using C# and added them as buttons in the CUI Ribbon. Is there an way execute command without displaying its command name in the command prompt.
_gile
If you call this command using Editor.Command, you can temporary set the CMDECHO system variable to 0.
Gilles Chanteau
GileCAD
GitHub
ActivistInvestor
Since your button click handlers run code in the application context, where the Editor's Command() method cannot be called directly without using ExecuteInCommandContextAsync() (which I don't recommend if it is only for the purpose of starting a command, without supplying parameters or additional input), you can just use the Document's SendStringToExecute() method to start your command, which has an argument indicating if the input should be echoed to the command line.
Another way to do this is to derive your buttons from Autodesk.AutoCAD.Ribbon.RibbonCommandButton, which has a Macro property that you can assign to the name of your command.
