Example: 2011 Thumbnail
Message 1 of 1
The firs onet gets the thumbnail of the layout you last saved in the drawing
The second gets all layout thumbnails
Will create a folder C:\AcadImages when netloaded and delete it when autocad closes
The thumbnail appeance depends on how your screen was when you last Saved
Another Idea is use ScreenCapture and around line 900 set
pofo.PreferCommandLine =  true
So you can send directly to the command prompt I started to mess with it post what I have but it is not very useful
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Windows
Imports System.Drawing
Imports System.IO
Imports System.Threading
Public Class Commands
    Implements IExtensionApplication
    <CommandMethod("DocumentThumbnail")> _
    Public Sub DocumentThumbnail()
        Dim doc As Document = DocumentManager.MdiActiveDocument
        doc.Database.ThumbnailBitmap.Save("C:\AcadImages\Doc.Png", System.Drawing.Imaging.ImageFormat.Png)
    End Sub
    <CommandMethod("AllLayoutsThumbnail")> _
Public Sub AllLayoutsThumbnail()
        Dim DB As Database = HostApplicationServices.WorkingDatabase
        Using trans As Transaction = DB.TransactionManager.StartTransaction
            Dim bt As BlockTable = DB.BlockTableId.GetObject(OpenMode.ForRead)
            For Each btrObjID As ObjectId In bt
                Dim btr As BlockTableRecord = btrObjID.GetObject(OpenMode.ForRead)
                If btr.IsLayout = True Then
                    Dim lyt As Layout = btr.LayoutId.GetObject(OpenMode.ForRead)
                    Dim btm As System.Drawing.Bitmap = lyt.Thumbnail
                    btm.Save(String.Format("{0}\{1}.Gif", "C:\AcadImages", lyt.LayoutName, System.Drawing.Imaging.ImageFormat.Gif))
            Next
        End Using
    End Sub
    ''' <summary>
    ''' This uses ScreenShot but you must REMOVESS if already loaded and add
    '''  pofo.PreferCommandLine = true and netload again around line 900 so msgbox does not pop up
    ''' It is buggy does not cause a exception but must hit return sometimes to make it work
    ''' Just started playing with it but I will post if anyway
    '''  </summary>
    ''' <remarks></remarks>
    <CommandMethod("UseScreenShot")> _
    Public Sub UseScreenShot()
        Try
                Dim btr As BlockTableRecord = doc.Database.CurrentSpaceId.GetObject(OpenMode.ForRead)
                    Dim lmts As Extents2d = lyt.Limits
                    Dim minPnt As String = lmts.MinPoint.ToString.Remove(lmts.MinPoint.ToString.Length - 1, 1)
                    Dim maxPnt As String = lmts.MaxPoint.ToString.Remove(lmts.MaxPoint.ToString.Length - 1, 1)
                    doc.SendStringToExecute( _
                    String.Format("{0}{1}{2}{3} ", "ScreenShot ", _
                                  minPnt.Remove(0, 1) & vbCrLf, _
                                  maxPnt.Remove(0, 1) & vbCrLf, "C:\AcadImages\Screenshot.Jpeg" & vbCrLf), _
                       True, False, False)
            End Using
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Sub
    Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
        If Not Directory.Exists("C:\AcadImages") Then
            Try
                Directory.CreateDirectory("C:\AcadImages")
            Catch ex As UnauthorizedAccessException
                MsgBox("Do Not Have Rights To Create Folder" & vbCrLf & _
 "Change File Path And Reload")
            End Try
    End Sub
    Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
        Directory.Delete("C:\AcadImages", True)
    End Sub
End Class
Replies (0)
