Error System.NullReferenceException in code - HELP!!!
What is wrong with this code, i allways get this error:
"System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.NullReferenceException: Object reference not set to an instance of an object.
at RSNNAcadApp.ExtendedCommands.Distance.DistanceOnCurve()"
[code]#region Using directives
using System;
//using System.Collections.Generic;
using System.Text;
using System.Threading;
using System.Globalization;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using System.Runtime.InteropServices;
#endregion
namespace RSNNAcadApp.ExtendedCommands
public class Distance
//this is an undocumented api exported from acad.exe. Use it at your own risk.
// Setting this flag tells AutoCAD to display the last string output to the command line
//in the Dynamic Input prompt window (one time only.)
[DllImport("acad.exe", EntryPoint = "?acedSetDynInputDisplayMessage@@YA_N_N@Z")]
private static extern bool acedSetDynInputDisplayMessage(bool displayMessageOnce);
private int Luprec = Application.DocumentManager.MdiActiveDocument.Database.Luprec;
private Curve CurveObj;
private Point3d FirstPoint;
private Point3d SecondPoint;
private double DistFP;
private double DistSP;
private double Dist;
private string DistFPPrompt;
private string DistSPPrompt;
private string DistPrompt;
public Distance()
[CommandMethod("AbstandKurve", CommandFlags.Modal)]
public void DistanceOnCurve()
Database db = HostApplicationServices.WorkingDatabase;
Transaction myT = db.TransactionManager.StartTransaction();
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
try
PromptEntityOptions entopts = new PromptEntityOptions("Objekt zeigen");
entopts.Message = "Objekt zeigen";
PromptEntityResult ent = null;
bool RightObject = false;
while (!RightObject)
while (ent.Status == PromptStatus.Error)
ent = ed.GetEntity(entopts);
if (ent.Status == PromptStatus.Cancel)
return;
if (ent.Status == PromptStatus.OK)
ObjectId entid1 = ent.ObjectId;
Entity tmpEnt = (Entity)myT.GetObject(entid1, OpenMode.ForRead);
CurveObj = tmpEnt as Curve;
if (CurveObj != null)
RightObject = true;
//highlight the entity
ObjectId[] ids = new ObjectId[1];
ids[0] = entid1;
SubentityId index = new SubentityId(SubentityType.Edge, 0);
FullSubentityPath path = new FullSubentityPath(ids, index);
tmpEnt.Highlight(path, true);
bool PromptCancel = false;
PromptPointOptions FPOption = new PromptPointOptions("Ersten Punkt angeben");
FPOption.Message = "Anfangspunkt zeigen";
PromptPointResult FPResult = null;
while (FPResult.Status == PromptStatus.Error)
FPResult = ed.GetPoint(FPOption);
FPOption.Message = "\nFalsche Eingabe. Richtung zeigen";
if (FPResult.Status == PromptStatus.Cancel)
PromptCancel = true;
if (FPResult.Status == PromptStatus.OK)
Point3d tmpStartPoint = FPResult.Value;
FirstPoint = CurveObj.GetClosestPointTo(tmpStartPoint, false);
DistFP = CurveObj.GetDistAtPoint(FirstPoint);
if (!PromptCancel)
PromptPointOptions SPOption = new PromptPointOptions("Zweiten Punkt angeben");
SPOption.BasePoint = FirstPoint;
SPOption.UseBasePoint = true;
SPOption.UseDashedLine = true;
SPOption.Message = "Richtung zeigen";
PromptPointResult SPResult = null;
while (SPResult.Status == PromptStatus.Error)
SPResult = ed.GetPoint(SPOption);
SPOption.Message = "\nFalsche Eingabe. Richtung zeigen";
if (SPResult.Status == PromptStatus.Cancel)
return;
if (SPResult.Status == PromptStatus.OK &&
Point3d tmpDirectionPoint = SPResult.Value;
SecondPoint = CurveObj.GetClosestPointTo(tmpDirectionPoint, false);
DistSP = CurveObj.GetDistAtPoint(SecondPoint);
tmpEnt.Unhighlight(path, false);
Thread.CurrentThread.CurrentCulture = new CultureInfo("en-us");
DistFPPrompt = DistFP.ToString("F" + Luprec.ToString());
DistSPPrompt = DistSP.ToString("F" + Luprec.ToString());
Dist = Math.Abs(DistSP - DistFP);
DistPrompt = Dist.ToString("F" + Luprec.ToString());
ed.WriteMessage(String.Format("\rAbstand = {0}, erster Punkt = {1}, zweiter Punkt = {2}",
DistPrompt, DistFPPrompt, DistSPPrompt));
acedSetDynInputDisplayMessage(true);
myT.Commit();
catch (System.Exception)
myT.Commit();
throw;
finally
myT.Dispose();
}[/code]
I've got it, it was just a silly mistake.
Changed:
[code] while (ent.Status == PromptStatus.Error)
}[/code]
To:
[code] do
} while (ent.Status == PromptStatus.Error);[/code]
and so on.
Roland
