Error starting cui editor
I am making a .NET-dll for AutoCAD. When I load it, it checks if a certain ribbon tab is defined (by name) and if so, it fills it in with buttons and stuff.
Everything works fine, except if I write the command "cui"! Then it suddenly complains about an unhandled exception:
"System.IO.FileNotFoundException: Could not load file or assembly 'AcCustomize.resources, Culture=nb-NO' or one of its dependencies. The system cannot find the file specified.
File name: 'AcCustomize.resources, Culture=nb-NO'"
The dll I am making is supposedly language neutral (both in the VS settings and when I look at properties of the finished dll). My PC has nb-NO as language.
But why doesn't this get a problem until I load this dll? I am literally loading houndreds of other dlls without problems...
Thank you for any tips!
Best regards,
Knut
It seems like the problem might be that I am inserting buttons on a cuix-file defined tab and this is somehow messing up the resource file structure. So now I am looking at a way to detect when the cui dialog is starting, to unload the buttons from the tab before the dialog comes up.
Tips still appreciated!
agaalen
Hi All,
We sometimes have the same problem, but I cannot seem to reproduce it.
anyone else made any findings that fixed the problem?
Kind regards,
Alain
