Error message
Error message
J-Rocks
Error message
J-Rocks
Hello guys
I am facing a problem with my learning example , can anybody have a look at the codes and why I have that warning message and how to fix this ?
Here is the C# codes :
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace ClassLibrary2
    class car
        int id;
        string color;
        string model;
        public void usage(int id, string color, string model)
        id = id;
        color = color;
        model = model;
        public void showme()
            Console.WriteLine("ID is : {0} \n Color is : {1} \n Model is : {2}", id, color,model);
    public class Class1
        static void main(string [] args)
            car mycar = new car();
            mycar.usage(10, "Black", "BMW");
            mycar.showme();
Thanks in advance .
SENL1362
This is a class project, which will be used as an extension to a (Main) program, such as AutoCAD.
Therefore this class cannot be started directly (from visual studio). Add AutoCAD to you're solution as a separate project, and set the property StartupProject
J-Rocks
Thank you SENL for your reply .
Tthe codes that I posted above is not to work with Autocad and it is a C sharp Class , I tried to right click on the class but nothing is prompted as you did on Autocad plugin .
I tried to start a new C# class file and the right click on the class brings nothing , any other solution .
Thank you so much .
SENL1362
Then this question does not belong to this forum.
However you can get this working by starting a new project of type Console Application, and past the code in that project.
J-Rocks
I made a mistake by using the console system in Class file , sorry for confusion .
I copied and pasted the codes in console file but the program is prompted with anther error message that maybe related the main function .
