Error eRegappIdNotFound is getting when i am submitting resultbuffer to Xdata
manohar2375
manohar2375
Hello All,
I am trying to attached XData to polyline but getting error Message = "eRegappIdNotFound" and please see the below code which i have written.
private void addXdataToPolyline(Polyline pline)
try
ResultBuffer plineXData = new ResultBuffer();
plineXData.Add(BaseXData.ApplicationName());
plineXData.Add(new TypedValue((int)DxfCode.ExtendedDataInteger16, 1002));
plineXData.Add(new TypedValue((int)DxfCode.ExtendedDataAsciiString, "MyLayerName"));
using (Transaction tran = pline.ObjectId.Database.TransactionManager.StartTransaction())
Entity ent = (Entity)tran.GetObject(pline.ObjectId, OpenMode.ForWrite);
ent.XData = plineXData;
tran.Commit();
catch (System.Exception ex)
var ed = Application.DocumentManager.MdiActiveDocument.Editor;
ed.WriteMessage($"{ex.Message}\n{ex.StackTrace}");
BaseXData.ApplicationName() is the function which will return [0]|{1001,ABC)} and plineXdata object contains below values:
[0]|{(1001,ABC}
[1]|{(1070,1002}
[2]|{(1002,MyLayerName}
Kindly help me where i did mistake then i will learn and proceed my work.
Thanks in Advance.
_gile
You have to check if the regap already exists and, if not, create it.
private void AddXdataToPolyline(Polyline pline)
    var db = pline.Database;
    using (var tr = db.TransactionManager.StartTransaction())
        var regAppTable = (RegAppTable)tr.GetObject(db.RegAppTableId, OpenMode.ForRead);
        if (!regAppTable.Has("ABC"))
            var regApp = new RegAppTableRecord();
            regApp.Name = "ABC";
            tr.GetObject(db.RegAppTableId, OpenMode.ForWrite);
            regAppTable.Add(regApp);
        var xdata = new ResultBuffer(
            new TypedValue(1001, "ABC"),
            new TypedValue(1017, 1002),
            new TypedValue(1002, YourLayerName));
        pline.XData = xdata;
        tr.Commit();
Gilles Chanteau
GileCAD
GitHub
manohar2375
Hello gile,
Good morning.
Thanks for your support and i have used above source code but i am getting error message ex.Message = "eInvalidResBuf".
Could you please suggest on this.
Thanks in Advance.
_gile
Oops!... A typo.
replace; new TypedValue(1017, 1002) with: new TypedValue(1070, 1002)
Gilles Chanteau
GileCAD
GitHub
manohar2375
Hello gile,
I have done this 'new TypedValue(1070, 1002)' then tried but it was hang at pline.XData = xdata;
Kindly help on this.
Thanks in Advance.
_gile
You did not show the code related to the polyline. the polyline have to be opened for write.
Gilles Chanteau
GileCAD
GitHub
manohar2375
Hi Sir,
Sorry for delay response and thanks for your support.
And i found my mistake and i am good to move further.
Again thanks for your valuable support.
