This will erase all the blocks in the blocks definitions
of the current drawing.
{code}
Public Sub eraseBlockDefinitions()
' get Local Drawing
Using db As Database = HostApplicationServices.WorkingDatabase()
Using tr As Transaction = db.TransactionManager.StartTransaction()
Dim dwg As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Using lock As DocumentLock = dwg.LockDocument
Using BT As BlockTable = dwg.Database.BlockTableId.GetObject(OpenMode.ForRead)
Using BTE As SymbolTableEnumerator = BT.GetEnumerator
' step through block definitions
While BTE.MoveNext = True
Try
Using myBTR As BlockTableRecord = BTE.Current.GetObject(OpenMode.ForWrite)
If Not myBTR.IsErased Then
' remove if you want to delete references also
If Not (myBTR.IsFromExternalReference Or myBTR.IsFromOverlayReference) Then
If Not myBTR.IsLayout Then
myBTR.Erase()
End Using
Catch ex As Exception
' msgbox("Something is wrong" & ex.tostring)
End Try
End While
' Commit changes
tr.Commit()
End Using
End Using
End Using
End Using
End Using
' Update Drawing View
regen()
End Sub
Sub regen()
Dim MyDWG As Autodesk.AutoCAD.ApplicationServices.Document
MyDWG = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim MyEd As EditorInput.Editor
MyEd = MyDWG.Editor
MyEd.Regen()
End Sub
{code}
(defun botsbuildbots() (botsbuildbots))
