Erase attribute inside block
kebby70
kebby70
I've erased attribute and correctlty erased.
but remained attribute inside block.(block edit)
Please See below code.
BlockReference blkRef = (BlockReference)acTrans.GetObject(blkId, OpenMode.ForWrite);
foreach (ObjectId attId in blkRef.AttributeCollection)
AttributeReference attRef = (AttributeReference)acTrans.GetObject(attId, OpenMode.ForWrite);
string tag = attRef.Tag.ToUpper();
string tagValue = attRef.TextString;
 if (attRef.Tag.StartsWith("test"))
attRef.Erase();
hosneyalaa
Hi
May add
Comment ATTSYNC
kebby70
Thanks hosneyalaa,
1. Erase attribue inside the block
2. Correctlry erased on attribute window or current drawing.
2. But Explode or Enter the block, remained attribute.
3. Block is rollbacked because the block has erased attribute if use ATTSYNC,
I'd like to erase attribute defination entity inside block.
kebby70
I've solved to erase/rename attribute and it works for me.
foreach (ObjectId blkId in objectIds)
BlockReference blkRef = (BlockReference)acTrans.GetObject(blkId, OpenMode.ForRead);
BlockTable acBlkTbl = acTrans.GetObject(acDocDb.BlockTableId, OpenMode.ForRead, false, true) as BlockTable;
BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl[blkRef.Name], OpenMode.ForRead, false, true) as BlockTableRecord;
AttributeReference attRef = (AttributeReference)acTrans.GetObject(attId, OpenMode.ForRead);
if (tag.StartsWith("AAA_"))
attRef.UpgradeOpen();
attRef.Erase();
attRef.DowngradeOpen();
foreach (ObjectId id in acBlkTblRec)
DBObject obj = id.GetObject(OpenMode.ForRead);
AttributeDefinition attDef = obj as AttributeDefinition;
if (attDef != null && !attDef.Constant)
if (attDef.Tag.StartsWith("AAA_"))
attDef.UpgradeOpen();
attDef.Erase();
attDef.DowngradeOpen();
