entity position deviates from the specified position while copy BlockReference by blockId
lixiaohai1222
Message 1 of 8
lixiaohai1222
        static void CopyBlocks()
            Database db = HostApplicationServices.WorkingDatabase;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            var dynBlockNames = new List<string> { "block1", "block2", "block3" };
            for (int i = 0; i < dynBlockNames.Count; i++)
                var basePoint = new Point3d(i, i, i);
                ObjectId blockId;
                BlockReference newBr;
                using (Transaction trans = db.TransactionManager.StartTransaction())
                    BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
                    newBr = new BlockReference(basePoint, bt["blockName"]);
                    BlockTableRecord modelSpace = trans.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite) as BlockTableRecord;
                    modelSpace.AppendEntity(newBr);
                    blockId = newBr.ObjectId;
                    trans.Commit();
                    for (int j = 100; j < 1000; i++)
                        var tp = new Point3d(j, j, j);
                        ed.Command("_.COPY", blockId, "", basePoint, tp);
                    trans.Commit();
something was wrong with the specified position "tp"
Replies (7)
Message 2 of 8
ActivistInvestor
What was wrong with the specified position?  You need to be more specific. What was the result verses what was expected result.
Running Object Snap perhaps ?
Message 3 of 8
lixiaohai1222
Message 4 of 8
lixiaohai1222
all the blocks specified by red arrow are also copied to wrong point
Message 5 of 8
_gile
There's something weird with this line:
 You're incrementing 'i' and 'j' is never incremented.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 6 of 8
_gile
Also, as @ActivistInvestor said, maybe something due to some running object snap. If you absolutely want to use Editor.Command, you should temporarily disable object snaps:
ed.Command("_.COPY", blockId, "", "_none", basePoint, tp);
But, instead of calling the COPY command, you could simply insert the new block references as you do for the "base" ones.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 8
lixiaohai1222
thanks, but dynamic properties will be lost while simply insert the new block references. In addition, when using DotNetARX.BlockTools.SetDynBlockValue to modify the attribute value of the new block references, AutoCAD will leak memory.
issue: https://forums.autodesk.com/t5/net/net-plugin-causes-high-memory-consumption-leak-not-in-managed/td-...
Message 8 of 8
norman.yuan
Well, using Editor.Command()/using command "COPY" does not change the fact that excessive use of dynamic blocks would result in high memory consumption. If you insert the block references with its default dynamic properties with code, there would be no extra memory consumption. The increased memory is resulted in when the block reference's dynamic properties are changed (each change would lead AutoCAD to create a new BlockTableRecord and its block reference). If you have a very complicated block definition (say many entities in it and these entities could be manipulated with dozens of dynamic properties), the BlockTableRecord could be quite big in size of memory. So, each instance of the block reference with a unique dynamic property value would lead AutoCAD to create new pair of an anonymous BlockTableRecord (with similar big amount of memory required) and a block reference. You can see, if you create 100 block references of this block with each of them has unique dynamic property value, you would end up with 100 big sized anonymous BlockTablerecords plus 100 instances of BlockReferences (paired to each anonymous block definition). Therefore, using big-sized/complicated dynamic blocks excessively would cause heavy overhead for AutoCAD process.
Norman Yuan
Drive CAD With Code
