END SEQUENCE Layer
END SEQUENCE Layer
END SEQUENCE Layer
hi,
is there a way i can get to the end sequence layer in blocks with attributes
i know it is the layer where the block is first placed in
i see there is a type  SequenceEnd but get and error when i try to get the objectid with fromacadobject function
Select objects:
BLOCK REFERENCE Layer: "FE_LICHT"
Space: Model space
Color: BYLAYER Linetype: "Continuous"
Handle = 1add
Block Name: "0MA58$"
at point, X=-18647.77 Y= -2431.94 Z= 0.00
X scale factor: 1000.00
Y scale factor: 1000.00
rotation angle: 90
Z scale factor: 1000.00
Scale uniformly: No
Allow exploding: Yes
ATTRIBUTE Layer: "21"
Space: Model space
Handle = 1ade
Style = "MONOTXT"
Annotative: No
Font file = MONOTXT
Press ENTER to continue:
mid point, X=-18647.77 Y= -2431.24 Z= 0.00
height 250.00
value M
tag TAG00
rotation angle 90
width scale factor 0.84
obliquing angle 0
flags normal
generation normal
END SEQUENCE Layer: "21"
Space: Model space
Color: 1 (red) Linetype: "Continuous"
Handle = 1adf
this is the listing in autocad
hope anyone know cant find nothing in google for .net only in lisp
hi all
i found out that i can get it away with entity.setlayerid method
but i still want to know if i can reference to that object
Alexander.Rivilis
I see two way:
1) Using P/Invoke for acdbEntNext and acdbGetAdsName
2) Using Filer as doing in MGDDBG utility:
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
hi alexander
will take a look at it
the MGDDBG utility i will definitely try
and thank u for making the explaining video
it will help me in the future too
Alexander.Rivilis
You can download MgdDbg bundle with source code from this URL: http://adn-cis.org/assets/gallery/AutoCAD/MgdDbg.zip and extract to C:\Program Files\Autodesk\ApplicationPlugins folder.
Expert Elite Member
thank u i have downloaded the file and will try it
