Emulate 3Drotate command
Hey there, quick question.
What I am trying to do is emulate the 3d rotate command to "stand up" an object, by rotating it 90 degrees.
Basically, I want the user to be able to select the object, and it will automatically rotate it 90 degreese about the right axis to stand it up. Eventually, I will make it so the user can select lots of objects and it will stand them all up.
I have looked at this example, http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html?url=WS1a919382... but I don't know if thats what I am trying to do. That looks like it's for more objects that are 3D already...
Any suggestions?
_gile
Look at the Entity.TransformBy() method.
This method requires a matrix 3d as argument.
The Matrix3d structure provides a Matrix3d.Rotation() static (Shared in VB) method which requires 3 arguments: the angle, the rotation axis and the center point.
Gilles Chanteau
GileCAD
GitHub
Alright, looking at that now, everything seems ok except for I do not know what the last paramter does
object.TransformBy(Matrix3d.Rotation(0.7854,
                                           curUCS.Zaxis,
                                           new Point3d(4, 4.25, 0)));
 Apparently it is the center point? Is that just the center of the object? How would I get that...
_gile
As with the 3DROTATE (or ROTATE3D) command, the user or the program have to specify the rotation base point.
Gilles Chanteau
GileCAD
GitHub
Could I somehow make the point be the same on all of the objects selected, like I could detect the bottom right corner or something?
