There's something wrong with my freeze layer procedure.
I get an eInvalidLayer error when it comes to changing the IsFrozen state.
Can anyone suggest what is causing it?
Public Sub LayerFreeze(ByVal sLayerName As String, ByVal bFreeze As Boolean)
'' Get the current document and database
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim acCurDb As Database = acDoc.Database
'' Start a transaction
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
'' Open the Layer table for read
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead)
Dim acLyrTblRec As LayerTableRecord
If acLyrTbl.Has(sLayerName) = False Then
acLyrTblRec = New LayerTableRecord()
'' Assign the layer a name
acLyrTblRec.Name = sLayerName
'' Upgrade the Layer table for write
acLyrTbl.UpgradeOpen()
'' Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec)
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
Else
acLyrTblRec = acTrans.GetObject(acLyrTbl(sLayerName), OpenMode.ForWrite)
' Freeze or thaw the layer
If acLyrTblRec.IsFrozen = Not bFreeze Then acLyrTblRec.IsFrozen = bFreeze
acTrans.Commit()
End Using
End Sub
