eInvalidInput when change SectionSettings' values
I use the GetClosestPointTo method to make sure the point on the curve
then I get a eInvalidInput error when using GetParameterAtPoint for a LWPolyline。
here is my code
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Geometry;
[assembly: CommandClass(typeof(test.Class1))]
namespace test
    public class Class1
        [CommandMethod("eg1")]
        public static void eg1()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            PromptEntityOptions peop = new PromptEntityOptions("\nchoose a polylne:");
            peop.SetRejectMessage("\n polyline only!");
            peop.AddAllowedClass(typeof(Polyline), true);
            PromptEntityResult res = ed.GetEntity(peop);
            if (res.Status != PromptStatus.OK)
                return;
            PromptPointOptions ppt = new PromptPointOptions("\nchoose a point:");
            PromptPointResult pptRes = ed.GetPoint(ppt);
            if (pptRes.Status != PromptStatus.OK)
                return;
            Polyline txt0 = null;
            using (Transaction trans = doc.Database.TransactionManager.StartTransaction())
                txt0 = trans.GetObject(res.ObjectId, OpenMode.ForWrite) as Polyline;
                trans.Commit();
            Point3d pt = txt0.GetClosestPointTo(pptRes.Value, true);
            double param1 = txt0.GetParameterAtPoint(pt);
            ed.WriteMessage("\nparam1=" + param1.ToString());
            double dis = txt0.GetDistAtPoint(pt);
            ed.WriteMessage("\ndis=" + dis.ToString());
and here is my drawing
_gile
You should call GetClosestPointTo(), GetParameterAtPoint() and GetDistAtPoint() within the transaction scope because when the transaction is disposed (at the end of the using code block), the polyline (which was opened by the transaction) will also be disposed.
To insure the point is on the curve, you should not call GetClosestPointTo() with the extend param set to true.
    Polyline txt0 = (Polyline)trans.GetObject(res.ObjectId, OpenMode.ForWrite);
    Point3d pt = txt0.GetClosestPointTo(pptRes.Value, false);
    trans.Commit();
Gilles Chanteau
GileCAD
GitHub
thank u so much.
but came with the same mistake after a few ‎Amendments
using System;
using System.Linq;
using System.Text;
namespace test
    public class Class1
                return;
                return;
                Polyline txt0 = trans.GetObject(res.ObjectId, OpenMode.ForWrite) as Polyline;
                trans.Commit();
_gile
I think this is due to this drawing.
AutoCAD looses its accuracy when entities are drawn far from the origin.
The coordinates of the block reference are around (35639000000, 2897900000).
If there's no imperative reason to draw so far from the origin, just move all entities nearer to (0,0).
Gilles Chanteau
GileCAD
GitHub
_gile
If there any reason you can't move the entities closer to the origin, you can just move the polyline, do the computation and move it back when done. You can use the picked point as displacement vector.
                return;
                return;
                Vector3d displacement = pptRes.Value.GetAsVector();
                txt0.TransformBy(Matrix3d.Displacement(displacement.Negate()));
                Point3d pt = txt0.GetClosestPointTo(Point3d.Origin, false);
                txt0.TransformBy(Matrix3d.Displacement(displacement));
                trans.Commit();
Gilles Chanteau
GileCAD
GitHub
Thank u so much.
