eInvaldInput error setting PlotPaperUnit.Inches
I am revising a vb.net program which inserts a standard drawing matte onto an empty paperspace layout.  The program contains a routine to check for the passed PlotSettings Object in the source drawing file and copy it to the current drawing's Layout1.  In this routine there is a line which sets the plotting units to inches and at this point the program generates an "unhandled exeception eInvalidInput...".  If I continue from this error, the program completes correctly so I am a bit puzzled as to what is causing it.  Here is the offending code:
            '**************** Destination Transaction Starts Here ****************             Using objTransaction As DatabaseServices.Transaction = objTransactionManager.StartTransaction()                 If SetLayoutAsCurrent(CONST_LAYOUT1, CallerName) Then                     ' The Layout Exists and is Current So Get a Reference to It Using the Layout Manager                     Dim objLayoutManager As LayoutManager = LayoutManager.Current                     Dim objLayout As Layout = objTransaction.GetObject(objLayoutManager.GetLayoutId(objLayoutManager.CurrentLayout), _        OpenMode.ForWrite)
                    ' '' Output the Name of the Current Layout and Its Device - Unremark for debugging                     ''objCurrentDrawing.Editor.WriteMessage(vbLf & "Current Layout: " & objLayout.LayoutName & vbLf)                     ''objCurrentDrawing.Editor.WriteMessage("Current Plot Configuration Name: " & objLayout.PlotConfigurationName & vbLf)
                    ' Reference the Destination PlotSettings Dictionary                     Dim objPlotSettingsDictionary As DBDictionary = objTransaction.GetObject(objDatabase.PlotSettingsDictionaryId, _        OpenMode.ForWrite)
                    ' If the Passed PlotSettings Object Exists in the Current Drawing, Delete It                     If objPlotSettingsDictionary.Contains(SourceName) Then                         objPlotSettingsDictionary.Remove(SourceName)                     End If                     objPlotSettingsDictionary = Nothing
                    ' Create the Destination PlotSettings Object and Populate It from the Source PlotSettings                     Dim objDestinationPlotSettings As PlotSettings = New PlotSettings(False)                     objDestinationPlotSettings.CopyFrom(objSourcePlotSettings)
                    ' Add the Plot Settings Object to the Destination Plot Settings Dictionary                     objDestinationPlotSettings.AddToPlotSettingsDictionary(objDatabase)
                    ' Confirm that the Copied PlotSettings Object Exists in the Current Drawing's Plot Settings Dictionary                     ' and Reset the Object to Pick Up the ID After It was Added to the Database                     ' If It was Not Found or Reset, We Need to Send a Message and  Exit This Function                     If Not ResetPlotSettingsObject(objDestinationPlotSettings, objTransaction, objDatabase, CONST_PROCEDURE_NAME) Then                         Dim strMessage = "The " & SourceName & " Page Setup Did Not Copy Correctly!" & vbCrLf & vbCrLf & _                                          "You Must Rebuild the " & SourceName.ToUpper & CONST_DWG_EXTENSION & " File." & vbCrLf & _                                          CONST_ERRMSG_FILE_LOCATION_SPE & _                                          CONST_ERRMSG_INSERTMAT_CLOSING                         MsgBox(strMessage, MsgBoxStyle.ApplicationModal + MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, CallerName)                         Return False                     End If
                    ' Update the PlotSettings Object to Make It Handle the Mat Insertion                     Dim objPlotSettingsValidator As PlotSettingsValidator = PlotSettingsValidator.Current                     'objPlotSettingsValidator.RefreshLists(objDestinationPlotSettings)                     ' Set Paper Unit to Inches                     objPlotSettingsValidator.SetPlotPaperUnits(objDestinationPlotSettings, PlotPaperUnit.Inches)
                    ' Set to Use a Standard Scale Type of 1:1, but Set Custom First to Make It Refresh                     ' Debugging Try... Catch Statement.  Uncomment to use                     'Try                     Dim cstDestination As New CustomScale(1.0, 1.0)                     objPlotSettingsValidator.SetCustomPrintScale(objDestinationPlotSettings, cstDestination)                     'Catch exAbut As Autodesk.AutoCAD.Runtime.Exception                     'If exAbut.ToString = "eInvalidInput" Then                     'MsgBox("Inserting Mat", vbOK)                     'End If
                    'End Try
                    objPlotSettingsValidator.SetStdScaleType(objDestinationPlotSettings, StdScaleType.StdScale1To1)                     objPlotSettingsValidator.SetUseStandardScale(objDestinationPlotSettings, True)                     objPlotSettingsValidator.SetZoomToPaperOnUpdate(objDestinationPlotSettings, True)
                    ' Set to Scale the Lineweights                     If Not objDestinationPlotSettings.ScaleLineweights Then                         objDestinationPlotSettings.ScaleLineweights = True                     End If
                    ' Copy the PlotSettings Object Values to the Layout                     objLayout.CopyFrom(objDestinationPlotSettings)
                    objCurrentDrawing.Editor.Regen()                     objCurrentDrawing.SendStringToExecute("_.zoom _e" & vbCr, True, False, True)
                    ' '' Output the Name of the Current Layout and Its Device - Unremark for debugging                     ''objCurrentDrawing.Editor.WriteMessage(vbLf & "Current Layout: " & objLayout.LayoutName & vbLf)                     ''objCurrentDrawing.Editor.WriteMessage("Current Plot PaperSize X: " & objLayout.PlotPaperSize.X & vbLf)                     ''objCurrentDrawing.Editor.WriteMessage("Current Plot PaperSize Y: " & objLayout.PlotPaperSize.Y & vbLf)
                    ' Downgrade the Current Layout Mode Back to Read                     objLayout.DowngradeOpen()
                    ' Commit and Save the Changes to the Current Drawing                     objTransaction.Commit()
                    ' Clean Up the Destination Objects                     objPlotSettingsValidator = Nothing                     objDestinationPlotSettings = Nothing                     objLayout = Nothing                 Else                     Dim strMessage = "Layout1 could Not be Set as the Current Layout!" & vbCrLf & vbCrLf & _                                      "Please be Sure That Layout1 Exists in the '" & objCurrentDrawing.Name & "' Drawing" & vbCrLf & _                                      "and Re-run the Insert Mat Utility." & vbCrLf & vbCrLf & _                                      "The Insert Mat Utility will Now be Terminated." & vbCrLf & _                                      "Use the AutoCAD 'Undo' Button to Undo Changes Made by This Utility."                     MsgBox(strMessage, MsgBoxStyle.ApplicationModal + MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, CallerName)                     ' Abort and Abandon the Changes to the Current Document                     objTransaction.Abort()                 End If             End Using     ' Destination Transaction
            ' Clean Up the Current Drawing Transaction Objects             objTransactionManager.Dispose()             objTransactionManager = Nothing             objDatabase = Nothing             objCurrentDrawing = Nothing
            ' Abort Any Changes to the Source Drawing             objSourceTransaction.Abort()
            ' Clean Up the Source Drawing Transaction Objects             objSourcePlotSettings = Nothing             objSourcePlotSettingsDictionary = Nothing         End Using     ' Source Transaction         objSourceTransactionManager.Dispose()         objSourceTransactionManager = Nothing         objSourceDatabase.Dispose()         objSourceDatabase = Nothing
        Return True     End Function  ' CopyPageSetupFromFile
Any suggestions would be appreciated.
Balaji_Ram
Hi John,
Sorry for the delay.
I have not come across any previous reports of such exception from the "SetPlotPaperUnits".
Can you please share a non-confidential buildable sample project for me to reproduce the exception ?
Thank you.
Balaji
Developer Technical Services
Autodesk Developer Network
