Edit Insertion Point of Existing Block
mcoH3VZV
mcoH3VZV
In the attached drawing file, I have two blocks. One is a blue rectangle that has its insertion point at 0,0. The other block has its insertion point at a lesser X and Y coordinate below 0,0.
Is there any way to edit the block in place so that the insertion point is right at 0,0? Would it be best to explode and re-block, or is there a way to do this easily?
I am using C# .NET
_gile
you have to compute the vector from (0, 0) to the block position, the open the block definition (BlockTableRecord) and displace all the entities it contains using this vector.
If you also want the block reference to stay at the same place, you have to dispace it with the negated vector.
Gilles Chanteau
GileCAD
GitHub
_gile
Here's a little example.
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using AcCoreAp = Autodesk.AutoCAD.ApplicationServices.Core.Application;
namespace MoveInsertionPointSample
    public class Commands
        [CommandMethod("TEST")]
        public static void Test()
            var doc = AcCoreAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var peo = new PromptEntityOptions("\nSelect block reference: ");
            peo.SetRejectMessage("\nSelected object is not a block reference.");
            peo.AddAllowedClass(typeof(BlockReference), true);
            var per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK)
                return;
            using (var tr = db.TransactionManager.StartTransaction())
                var br = (BlockReference)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
                var dp = br.Position.GetAsVector();
                var xform = Matrix3d.Displacement(dp);
                var btr = (BlockTableRecord)tr.GetObject(br.BlockTableRecord, OpenMode.ForRead);
                foreach (ObjectId id in btr)
                    var ent = (Entity)tr.GetObject(id, OpenMode.ForWrite);
                    ent.TransformBy(xform);
                br.TransformBy(Matrix3d.Displacement(dp.Negate()));
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
mcoH3VZV
Excellent as always, Thank you.
