Edit attribute reference value of a block reference
jptallano
jptallano
Using code I found in this forum, I wrote a small method for setting the value of a given attribute reference in a block reference:
public static void SetBlockAttributeValue(ObjectId objectId, string attributeTag, string attributeValue)
    using (Transaction acTrans = application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction())
        try
            BlockTable bt = (BlockTable)acTrans.GetObject(application.DocumentManager.MdiActiveDocument.Database.BlockTableId, OpenMode.ForRead);
            BlockTableRecord btr = (BlockTableRecord)acTrans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
            BlockReference block = (BlockReference)acTrans.GetObject(objectId, OpenMode.ForWrite);
            foreach (ObjectId attId in block.AttributeCollection)
                AttributeReference attRef = (AttributeReference)acTrans.GetObject(attId, OpenMode.ForWrite);
                if (attRef.Tag.ToUpper() == attributeTag.ToUpper())
                    attRef.TextString = attributeValue;
                    break;
            acTrans.Commit();
        catch (System.Exception ex)
            application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nException reading '" + attributeTag + "' on entity " + objectId + ": " + ex.Message);
Through debugging, I can see that the attribute reference's TextString value is set correctly. Problem is the value is not recorded and the attribute reference value stays the same, as if the Commit() didn't happen. What am I doing wrong?
_gile
You should show the code which calls the SetBlockAttributeValue method.
If the calling code launch this method from within a Transaction which is not commited,  the nested transaction will be rolled back.
Gilles Chanteau
GileCAD
GitHub
jptallano
Forget it guys, the method works, the problem came from a mess of transactions outside of it. Sorry!
jptallano
Yes, that was exactly the problem. 😄
