ed.Command
ed.Command
SRSDS
Advisor Advisor
Message 1 of 11
ed.Command
SRSDS
Can I ask how the ed.Command works?
I really need to create a cloud from a polyline  object and the simplest way I can find  is this:
ed.Command("_revcloud", "_arc", 2.0 / scale, 6.0 / scale, "_object", polyId, "_no")
Obviously sends a commands to the command line to convert it but I get an eInValidInput error.
Replies (10)
Message 2 of 11
Alexander.Rivilis
1. AutoCAD version?
2. ed.Command started in context of document or in context of application?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 11
SRSDS
Maybe in context of application? Not entirely sure what that means
  Public Sub RevCloud(polyId As ObjectId, scale As Double)
        Dim doc = Application.DocumentManager.MdiActiveDocument
        Dim db = doc.Database
        Dim ed = doc.Editor
    End Sub
Message 4 of 11
Alexander.Rivilis
@SRSDS
Editor.Command can not be used in application context. E.g. this method can be used in document context - only within command without SESSION flag.
Expert Elite Member
Message 5 of 11
SRSDS
I'm still unclear on this.
I converted the code from this link to VB and inserted it.
http://www.tek1.com.au/turning-autocad-curves-revision-clouds-autocad-net-api/
On the line:
ed.Command("_.REVCLOUD", "", "O", "", ss, "")
I get an error saying 'Command' is not a member of 'Editor'.
Message 6 of 11
ActivistInvestor
Then you're using an older product release.
Search this discussion group for "GenerateRunCommand", and you'll find an implementation for older releases that do not expose Command().
Message 7 of 11
SRSDS
That was it!
I had ACAD 2013 references.
Thank you.
Message 8 of 11
Alexander.Rivilis
You was talking about AutoCAD 2018 before.
Expert Elite Member
Message 9 of 11
SRSDS
I wasn't thinking in the right terms. Sorry.
I am running AutoCAD 2018 but my project uses the reference .dll files from 2013
Message 10 of 11
Alexander.Rivilis
It is wrong practice because some classes/methods changed, some methods removed, some methods added.
Expert Elite Member
Message 11 of 11
_gile
You'll have to build, at least, two different projects:
  • one project targeting AutoCAD 2013 and 2014 which uses the wrapper for RunCommand()
  • one project targeting AutoCAD 2015 and later which uses the new Editor.Command() method (because the wrapper wont work with these versions)
Gilles Chanteau
GileCAD
GitHub
