Dynamic Block Hatch Not Updating to New Contour After Parameter Change
M_Kocyigit
M_Kocyigit
I’m working with AutoCAD 2019 and insert dynamic blocks with visibility parameters via a .NET method, but the hatches do not automatically adjust to the new contour of the cross-section after parameter changes – is there a solution for this?
M_Kocyigit
After extensive research, I was finally able to solve the problem. The magic word is EvaluateHatch.
        /// <summary>
        /// Re-evaluates all <see cref="Hatch"/> objects that belong to the block definition
        /// used by the given block reference, and marks the reference graphics as modified (regen).
        /// </summary>
        /// <param name="blockRefId">
        /// ObjectId of the <see cref="BlockReference"/> to refresh.
        /// </param>
        public static void
        ReevaluateHatchesInBlock ( ObjectId blockRefId )
            if ( blockRefId.IsNull || blockRefId.IsErased || !blockRefId.IsValid )
                return;
            var db = blockRefId.Database;
            using ( var tr = db.TransactionManager.StartTransaction() )
                var br = tr.GetObject ( blockRefId, OpenMode.ForRead, false ) as BlockReference;
                if ( br == null || br.IsErased )
                    tr.Abort();
                    return;
                var btr = tr.GetObject(br.BlockTableRecord, OpenMode.ForRead, false) as BlockTableRecord;
                if ( btr != null && !btr.IsErased )
                    foreach (ObjectId entId in btr)
                        var hatch = tr.GetObject(entId, OpenMode.ForRead, false) as Hatch;
                        if (hatch != null && !hatch.IsErased)
                            // Open in write mode to run EvaluateHatch
                            hatch.UpgradeOpen   ( );
                            hatch.EvaluateHatch ( true );
                // Refresh the display of the BlockReference
                br.UpgradeOpen            ( );
                br.RecordGraphicsModified ( true );
             // br.Draw();
                tr.Commit();
