Dynamic block doesnt correctly update after property value change
Message 1 of 1
I'm writing a script that needs to update a dynamic block reference size. When I modify the block reference through the DynamicBlockReferencePropertyCollection, it doesn't get visually updated in the same way as it would if I would move the grip.
Code:
		private void UpdateBlockReferenceParameter(Database db, BlockReference blockRef, int referenceIndex, double value)
            var objectID = blockRef.Id;
			using (Transaction transaction = db.TransactionManager.StartTransaction())
				DBObject obj = transaction.GetObject(objectID, OpenMode.ForWrite);
				BlockReference br = ((BlockReference)obj);
				br.DynamicBlockReferencePropertyCollection[referenceIndex].Value = value;
				transaction.Commit();
		for (int i=0; i<br.DynamicBlockReferencePropertyCollection.Count; i++)
			if (br.DynamicBlockReferencePropertyCollection[i].UnitsType == DynamicBlockReferencePropertyUnitsType.Distance)
				UpdateBlockReferenceParameter(database, br, i, (double)(200 + i));
And this is the result:
On the top: the original
In the middle: the dynamic block after running this snippet
On the bottom: the same dynamic block after moving the grip.
The middle version (which is the problem) fixes itself if I move the grip by a small amount after running the script.
What is wrong with what I am doing? How can it be solved?
Replies (0)
