Drawing polyine
Drawing polyine
Drawing polyine
Hi everyone
I'm trying to write something that gets the user to draw a closed polyline after a button is pressed on a form.
I tried using the CommandAsync method to send the PLINE command to autocad but using that didn't allow me to execute code after the polyline was drawn so I am currently using the method of creating a polyline object and adding vertices to it based on where the user clicks, however the problem with this method is that it does not show the line as I'm drawing it which would make it difficult for users to know where exactly they've drawn.
My question is, can I get autocad to show the lines of the polyline in the drawing as I add vertices?
Joel
hgasty1001
Try this article from Kean's blog: Polyline Jig  also this article from Norman Yuang's excelent blog it's very insightful: Tracing over a Polyline
Gaston Nunez
Thanks Gaston. I think this is exactly what I was looking for!
_gile
Here's a simpler exampe just using a base point in a GetPoint loop (works with straight segments on the current UCS plane).
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace DrawPline
    public class Commands
        [CommandMethod("TEST")]
        public void Test()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptPointOptions opts = new PromptPointOptions("\nSpecify the first point: ");
            PromptPointResult result = ed.GetPoint(opts);
            if (result.Status != PromptStatus.OK)
                return;
            opts.Message = "\nSpecify next point: ";
            opts.AllowNone = true;
            opts.UseBasePoint = true;
            Matrix3d ucsMat = ed.CurrentUserCoordinateSystem;
            CoordinateSystem3d ucs = ucsMat.CoordinateSystem3d;
            Plane plane = new Plane(Point3d.Origin, ucs.Zaxis);
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord space =
                    (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                using (Polyline pline = new Polyline())
                    pline.Normal = ucs.Zaxis;
                    pline.Elevation = ucs.Origin.Z;
                    pline.AddVertexAt(0, result.Value.TransformBy(ucsMat).Convert2d(plane), 0.0, 0.0, 0.0);
                    space.AppendEntity(pline);
                    tr.AddNewlyCreatedDBObject(pline, true);
                    int i = 1;
                    while (true)
                        opts.BasePoint = result.Value;
                        if (result.Status == PromptStatus.Cancel)
                            return;
                        if (result.Status == PromptStatus.Keyword)
                            pline.Closed = true;
                            break;
                            break;
                        if (i == 2)
                            opts.SetMessageAndKeywords("\nSpecify next point [Close]: ", "Close");
                        pline.AddVertexAt(i++, result.Value.TransformBy(ucsMat).Convert2d(plane), 0.0, 0.0, 0.0);
                        db.TransactionManager.QueueForGraphicsFlush();
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
_gile
The same with an Undo option.
using System;
using System.Collections.Generic;
namespace DrawPline
        public void Test()
            if (result.Status != PromptStatus.OK)return;
            Stack<Point3d> points = new Stack<Point3d>();
            points.Push(result.Value);
            Func<Point3d, Point2d> conv2d = p => p.TransformBy(ucsMat).Convert2d(plane);
            Autodesk.AutoCAD.DatabaseServices.TransactionManager transMgr = db.TransactionManager;
            using (Transaction tr = transMgr.StartTransaction())
                    pline.AddVertexAt(0, conv2d(points.Peek()), 0.0, 0.0, 0.0);
                    while (true)
                        switch (points.Count)
                            case 1:
                                opts = new PromptPointOptions("\nSpecify next point: ");
                                break;
                            case 2:
                                opts.SetMessageAndKeywords("\nSpecify next point [Undo]: ", "Undo");
                                break;
                            default:
                                opts.SetMessageAndKeywords("\nSpecify next point [Undo/Close]: ", "Undo Close");
                                break;
                        opts.BasePoint = points.Peek();
                        if (result.Status == PromptStatus.Cancel) return;
                            if (result.StringResult.ToUpper() == "CLOSE")
                                break;
                            else
                                points.Pop();
                                pline.RemoveVertexAt(points.Count);
                                continue;
                            if (points.Count > 1) break;
                            else return;
                        pline.AddVertexAt(points.Count - 1, conv2d(points.Peek()), 0.0, 0.0, 0.0);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Thanks Gilles. That's really helpful too.
