Draw line with angle && Continue line with another angle(); .Net
Message 1 of 13
I want to draw a line which starts from user insertion point with an angle (180 deg) of length x,
and wanted to draw another lines on both the end points vertical down with an angle (270 deg ) of length x on both sides
please help me whats gone wrong with my code
Thanks in Advance ;;
double angle = 180;
double length = 50;
double angle1 = 270;
double length1 = 10;
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
PromptPointOptions ppo = new PromptPointOptions("Please Specify the Point");
PromptPointResult ppr = ed.GetPoint(ppo);
if (ppr.Status != PromptStatus.OK)
return;
Point3d startPt = ppr.Value;
Point3d endPt = new Point3d(startPt.X + Math.Cos(angle) * length, startPt.Y + Math.Sin(angle) * length, 0);
Line l1 = new Line(startPt, endPt);
btr.AppendEntity(l1);
tr.AddNewlyCreatedDBObject(l1, true);
//Secondline
Point3d endPt2 = new Point3d(endPt.X + Math.Cos(angle1) * length1, endPt.Y + Math.Sin(angle1) * length1, 0);
Line l2 = new Line(endPt, endPt2);
btr.AppendEntity(l2);
//Thirdline
Point3d endPt3 = new Point3d(endPt.X + Math.Cos(angle1) * length1 , endPt.Y + Math.Sin(angle1) * length1 , 0);
Line l3 = new Line(startPt, endPt3);
btr.AppendEntity(l3);
tr.Commit();
Replies (12)
Message 2 of 13
Juergen_Becker
in all the languages (Visual Lisp, .Net etc.) you have to use angle in radians (PI) not in decimal.
180° = 1PI
90 = 1/2 PI
please try that before other problems has to be resolved.
        public static double RadAngle(double doubleAngle)
            return doubleAngle * System.Math.PI / 180;
        public static double DecAngle(double RadAngle)
            return RadAngle * 180 / System.Math.PI;
Use above Code to convert from one to another.
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
Message 3 of 13
ActivistInvestor
Using the extension methods included below,
   double angle = 180;
   double length = 50;
   Point3d endPt = startPt.To(angle.ToRadians(), length);
   //Secondline
   Point3d endPt2 = startPt.To(angle1.ToRadians(), length1);
   //Thirdline
   Point3d endPt3 = endPt.To(angle1.ToRadians(), length1);
Extension methods for converting from angle/radians and computing polar coordinates:
using System;
using Autodesk.AutoCAD.Geometry;
namespace Autodesk.AutoCAD.Geometry
   public static class MyGeometryExtensions
      /// <summary>
      /// Converts a double representing an angle in radians to degrees
      /// </summary>
      /// <param name="radians">The angle in radians</param>
      /// <returns>The angle in degrees</returns>
      public static double ToDegrees(this double radians)
         return ((radians / 3.1415926535897931) * 180.0);
      /// <summary>
      /// Converts a double representing an angle in degrees to radians
      /// </summary>
      /// <param name="degrees">The angle in degrees</param>
      /// <returns>The angle in radians</returns>
      public static double ToRadians(this double degrees)
         return ((degrees / 180.0) * 3.1415926535897931);
      /// <summary>
      /// 2D Polar coordinate specificiation (basepoint/angle/distance)
      /// </summary>
      /// <param name="basepoint">The basepoint from which the resulting point is computed</param>
      /// <param name="AngleInXYPlane">The direction (in radians) to the resulting point</param>
      /// <param name="distance">The distance to the resulting point</param>
      /// <returns>The point at the given distance and direction from the base point</returns>
      public static Point3d To(this Point3d basepoint, double angleInXYPlane, double distance)
         return new Point3d(
            basepoint.X + (distance * Math.Cos(angleInXYPlane)),
            basepoint.Y + (distance * Math.Sin(angleInXYPlane)),
            basepoint.Z);
Message 4 of 13
Juergen_Becker
please use System.Math.PI instead of 3.1415926535897931.
Regards Jürgen
Thanks.
Jürgen A. Becker
Building Services
CAD-Becker.de
Message 5 of 13
ActivistInvestor
Regards Jürgen
That's the value of Math.PI.
Message 6 of 13
Juergen_Becker
I have to contradict that because the number pi does not end otherwise the result will be inaccurate.
That's important when big coordinates are used.
Regards Jürgen
Thanks.
Jürgen A. Becker
Building Services
CAD-Becker.de
Message 7 of 13
_gile
Regards Jürgen
Did you just try something like this?
Console.WriteLine("{0:R}",Math.PI);
or like this:
Console.WriteLine(Math.PI == 3.1415926535897930);
Console.WriteLine(Math.PI == 3.1415926535897931);
Console.WriteLine(Math.PI == 3.1415926535897932);
You should learn a little about double-precision floating-point before asserting things about System.Math.PI accuracy.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 13
ActivistInvestor
Regards Jürgen
I think you're mistaken.  Math.PI is a const, not a function or a number of infinite resolution.
The compiler replaces references to a const with the value it is defined to, so the compiled code does not contain "Math.PI", it contains the value shown below, that PI is defined to by the System.Math class:
   // Portion of the System.Math class as rendered by ILSpy:
namespace System
public static class Math { private static double doubleRoundLimit = 1E+16; private const int maxRoundingDigits = 15; /// <summary>Represents the ratio of the circumference of a circle to its diameter, specified by the constant, PI.</summary>
[__DynamicallyInvokable] public const double PI = 3.1415926535897931; //// <<<remainder of Math class omitted>>> }
Message 9 of 13
Juergen_Becker
I know what double is. You do not have to teach me.
Nevertheless, use Math.PI.
Regards Jürgen
Thanks.
Jürgen A. Becker
Building Services
CAD-Becker.de
Message 10 of 13
ActivistInvestor
Regards Jürgen
You obviously do not know what a const is, because you mistakenly believe that the use of 'Math.PI' results in a more-precise value than the literal value that I used in the code I posted.
So, let me say this to you again one more time: Math.PI is a const defined by the Math class, and its defined value is 3.1415926535897931
We will use whatever we care to use, as long as it is correct.
Message 11 of 13
Juergen_Becker
I also know what a const is.
What I want to say is that you better use System.Math.PI because
1. You don't have to declare your own PI
2. You can't do any mistakes.
What about this?
        static void Main()
            Application.EnableVisualStyles();
            Application.SetCompatibleTextRenderingDefault(false);
            decimal m_PI = 0;
            m_PI = PI();
            Application.Run(new Form1());
        static decimal PI()
            return PI(1) * 2;
        static decimal PI(int i)
            if (i > 60)
                return i;
            else
                return 1 + (i / (1 + (2.0m * i))) * PI(i + 1) ;
This Little Code return PI as a decimal with much more precision.
Regards Jürgen
Thanks.
Jürgen A. Becker
Building Services
CAD-Becker.de
Message 12 of 13
_gile
What about this?
        static void Main()
            decimal m_PI = 0;
            m_PI = PI();
        static decimal PI()
            return PI(1) * 2;
            if (i > 60)
                return i;
            else
So what?
Even implemented in a more usable way (as the following code examples), to be used with AutoCAD (which only uses the Double type for floating numbers), MathExtension.PI will have to be converted into a double, and (double)MathExtension.PI returns: 3.1415926535897931, which is the same as System.Math.PI value...
    public class MathExtension
        static MathExtension()
            PI = 2 * ComputePI(1);
        public static decimal PI { get; }
        static decimal ComputePI(int i)
            if (i > 60)
                return i;
            else
                return 1 + (i / (1 + (2.0m * i))) * ComputePI(i + 1);
or, equivalent, but much more simple and direct (as you know what a const is):
    public static class MathExtension
        public const decimal PI = 3.141592653589793250103076431m;
Gilles Chanteau
GileCAD
GitHub
Message 13 of 13
ActivistInvestor
You do not know what a const is, as you made that perfectly clear in your first reply, by suggesting that Math.PI is more accurate than the literal const value in my code, which is the value that Math.PI is defined as in System.Math. You are completely mistaken about that, so don't try to change the story now.
You also do not understand that a System.Double's precision is limited to 15 places to the right of the decimal point.
It does not matter what the resolution of a System.Decimal is, because computations are always done using System.Double, not System.Decimal, and all APIs that accept radian angle arguments declare tham as System.Double, not System.Decimal.
Here is another portion of the disassembled code of System.Math, do you see any parameters declared as decimal ?
public static extern double Acos(double d); public static extern double Asin(double d); public static extern double Atan(double d); public static extern double Atan2(double y, double x);
What about this?
        static void Main()
            decimal m_PI = 0;
            m_PI = PI();
        static decimal PI()
            return PI(1) * 2;
            if (i > 60)
                return i;
            else
Regards Jürgen
