Draw custom rubberband between two points
fehrsZBFB9
fehrsZBFB9
Hallo Guys,
I have point input scenario where I want to draw a rubberband between the mouse cursor and the nearest point on a line. The base point is constantly changing. I currently use an InputPointMonitor combined with the TransientManager to draw this line but it should look exactly like a rubberband. Is there a way to get AutoCAD draw this rubberband? If not, is there a way to obtain the rubberband's color and pattern?
ActivistInvestor
You can use a Jig, and set the BasePoint Property of the JigPromptOptions-based type inside of the Sampler() method
fehrsZBFB9
Thanks. I have to look at Jig-Classes first before I cann accept your solution. I never used them in .NET.
ActivistInvestor
