Does Application class have a "BeginDoubleClick" event?
norman.yuan
Mentor Mentor
Message 1 of 8
norman.yuan
In resently available "AutoCAD .NET Developer Guide" (http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html), "Use Event" chapter lists that Application class has a "BeginDoubleClick" event. However, I cannot find this event in VS's object brower. I am using AutoCAD2009. I also has documentation from AutoCAD2010 SDK, in which, the .NET API's Application class also does not have a "BeginDoubleClick" event.
So, can someone tell me if I missed something, or some insider know this event will be only available for future version, say 2011 (because the author put it into this developer guide, he might know the next version, natually)?
Norman Yuan
Drive CAD With Code
Replies (7)
Message 2 of 8
The event is there.
Perhaps you're seeing the System.Windows.Forms.Application class (or its WPF
counterpart) in intellisense?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:[email protected]...
natually)?
Message 3 of 8
I do not see it in 2009 either (see attached) as well as a couple of others they list. I do not have 2010 installed but would assume they are there and are new.
Message 4 of 8
No, I did meant Autodesk.AutoCAD.ApplicationServices.Application class. As I
said, I am using Acad2009. As Nathtay's reply suggested, this event does not
exist at least until Acad2009.
I only checked Acad2010' documentation in downloaded Acad2010 SDK yesterday.
According to the document the event does not exist. But now when I changed
refernce to "acmdg.dll" in a VS project to the one from Acad2010SDK, the
event is there. So, it is just another typicl Autodesk behaviour of very
poor documentation: it is too busy on yearly release to update the
documentation.
"Tony Tanzillo" wrote in message
The event is there.
natually)?
Message 5 of 8
I use Reflector so it may be showing things that the object browser may not
show depending on the settings for the browser.
"Norman Yuan" wrote in message
documentation.
The event is there.
natually)?
Message 6 of 8
So are you saying the event exists in 2009?
Message 7 of 8
I noticed in your screenshot that you have "Custom Component Set" selected.
Can you verify that the acmgd listed is for 2009 (click on acmgd in left pane of Object Browser)?
Should say something like:
Assembly acmgd
C:\Program Files\AutoCAD 2009\acmgd.dll
I looked in 2010 and it is there. I don't have 2009 installed right now.
Message 8 of 8
The custom component set consists of acmgd.dll and acdbmgd.dll for version 2009.
