documentation on how to connect to autocad from an exe in vb.net
Where is the documentation on how to connect to autocad from an exe in vb.net?
The ObjectARX is not appropriate, and the standard VBA code doesn't works.
I had spent hours trying to find how to replace "ThisDrawing" (=autocad drawing on VBA) on a VB.NET project to create a new layer.
I cannot find the VB.NET way of doing ThisDrawing.Layers.Add(layerName)
Here it says
@StephenPreston wrote:
The .NET equivalent of ThisDrawing is Application.DocumentManager.mdiActiveDocument.Database. The Database class has a Filename property that returns the DWG filepath and name.
but that's only available from ObjectARX, which cannot be accessed from an EXE
norman.yuan
Well, I am not a fan of using EXE to control AutoCAD, as I said in other post, here is the usual way to do it:
Dim cadApp As AcadApplciation = Nothing
Dim doc As AcadDocument = Nothing
Try
  '' Connect to existing AutoCAD session
  cadApp=GetObject(, "AutoCAD.Application")
Catch
  '' If no existing AutoCAD session, start one
  Try
    cadApp = CreateObject("AutoCAD.Application")
  Catch
    MsgBox("Cannot connect to AutoCAD!")
    Return
  End Try
End Try
doc=cadApp.Documents.Open("c:\....\myDrawingh.dwg"....)
Now you have the AcadDocument that is equivalent to ThisDrawing in VBA. Do whatever you want to, as you do in AutoCAD VBA, just be aware of the syntext different from VB.NET and VBA.
Norman Yuan
Drive CAD With Code
Ok, but where is the documentation?
