Dockable container IN c# .NET
s_abeed
s_abeed
Is there a sample code, implementing the dockable container in C# .NET that I can pick to modify further?
ActivistInvestor
I'll assume you're referring to the DockableContainer ActiveX control that was commonly used in VBA and Visual Basic long ago, authored by Jorge Lopez.
There isn't any need for that in .NET. It includes the PalletSet class which allows you to create dockable UI's easily.
You will find a file attached to this post that has an example of its use.
