Do zoom extents in C# .NET (AutoCAD)
Message 1 of 8
Hi!!
I am developing a plugin for AutoCAD and I want to Know how to do Zoom Extents in C# .NET
Replies (7)
Message 2 of 8
_gile
The shorter and simpler way is to call the COM AcadApplication.ZoomExtents() method. This can be done without referencing COM libraries by using the dynamic type
dynamic acadApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
acadApp.ZoomExtents();
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
_gile
You can also use the following extension method:
    public static class EditorExtension
        public static void Zoom(this Editor ed, Extents3d ext)
            if (ed == null)
                throw new ArgumentNullException("ed");
            using (ViewTableRecord view = ed.GetCurrentView())
                Matrix3d worldToEye = Matrix3d.WorldToPlane(view.ViewDirection) *
                    Matrix3d.Displacement(Point3d.Origin - view.Target) *
                    Matrix3d.Rotation(view.ViewTwist, view.ViewDirection, view.Target);
                ext.TransformBy(worldToEye);
                view.Width = ext.MaxPoint.X - ext.MinPoint.X;
                view.Height = ext.MaxPoint.Y - ext.MinPoint.Y;
                view.CenterPoint = new Point2d(
                    (ext.MaxPoint.X + ext.MinPoint.X) / 2.0,
                    (ext.MaxPoint.Y + ext.MinPoint.Y) / 2.0);
                ed.SetCurrentView(view);
        public static void ZoomExtents(this Editor ed)
            Database db = ed.Document.Database;
            db.UpdateExt(false);
            Extents3d ext = (short)Application.GetSystemVariable("cvport") == 1 ?
                new Extents3d(db.Pextmin, db.Pextmax) :
                new Extents3d(db.Extmin, db.Extmax);
            ed.Zoom(ext);
 Using
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
ed.ZoomExtents();
Gilles Chanteau
GileCAD
GitHub
Message 4 of 8
Hi Gile,
I was trying to use your code to zoom extents and I'm getting an eNotApplicable error in the line
Basically the codes that call this methos is
DocumentCollection docCollection = Application.DocumentManager;
doc = docCollection.Open(dwg.ToString(), false, null);
Application.DocumentManager.MdiActiveDocument = doc;
using (doc.LockDocument())
LayoutManager.Current.CurrentLayout = "Model";
doc.Editor.ZoomExtents(); ----->Here I get the exception
Message 5 of 8
_gile
There's nothing wrong with the code you show. The error is due to something else.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 8
Thanks Gilles, looks like it was a session flag problem.
Message 7 of 8
1603567506
Observer
Observer
If I write it this way, he will shrink the window and move the coordinates to a very large position. Why is that?
Message 8 of 8
nshupeFMPE3
May I ask a question about this? You mention not needing to reference COM libraries. I recently went through a lot of learning around COM and the C++ api for AutoCAD in order to get this code from Kean to work for adding properties to the Properties window in ACAD. But in using dynamic like you show above, are you accessing the underlying objects, not just those that are exposed to .NET?
