dll loaded success, but Initialize doesn't work
adn019LKFW
Message 1 of 10
adn019LKFW
I use the netload command to load my dll, but the code in MyApp.Initialize() doesn't execute and my command doesn't work. This problem does not appear on the cad2012 version, but sometimes it occurs in the cad2016,2018,2020 version.
If I build new project, this problem does not appear.
So what's wrong with my project?
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
[assembly: ExtensionApplication(typeof(MyNamespace.MyApp))]
namespace MyNamespace{
public class MyApp : IExtensionApplication
    public void Initialize()
        Document doc = Application.DocumentManager.MdiActiveDocument;
        Editor ed = doc.Editor;
        ed.WriteMessage("MyDll load success");
    //...other code
Replies (9)
Message 2 of 10
_gile
A project referencing AutoCAD 2012 libraries (AcDbMgd.ll and AcMgd.dll) won't work on later versions. You have to build a new project referencing AcCoreMgd.dill, AcDbMgd.ll and AcMgd.dll from AutoCAD 2013 or later libraries.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 10
adn019LKFW
Thank you for your reply,
I'm using different project for each cad version, and both correctly reference the corresponding version of the dlls.
So it doesn't look like the problem is caused by this reason.
Message 4 of 10
Alexander.Rivilis
You have to compare Application.DocumentManager.MdiActiveDocument and null before call doc.Editor.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 5 of 10
adn019LKFW
I'm sure Application.DocumentManager.MdiActiveDocument is not null.
I try to attach to acad.exe in debug mode,  Initialize() is not invoked.
Message 6 of 10
_gile
In addition to @Alexander.Rivilis said, you should also handle the Apllication.Idle event.
            Application.Idle += OnIdle;
        private void OnIdle(object sender, EventArgs e)
            var doc = Application.DocumentManager.MdiActiveDocument;
            if (doc != null)
                Application.Idle -= OnIdle;
                doc.Editor.WriteMessage("\nMyDll load success.\n");
Gilles Chanteau
GileCAD
GitHub
Message 7 of 10
adn019LKFW
I rebuild the project a few times without any modification and it works. It's so weird.
Message 8 of 10
CadWCCNL
I remember seeing something like this in Helper.cs.
..\Autodesk\ObjectARX_for_AutoCAD_2023_Win_64bit_dlm\samples\dotNet\EventsWatcher
try
	// Application.DocumentManager.Count should be used to check zero doc status
	// MdiActiveDocument returns non null sometimes even if in zero doc status!
	if(	Application.DocumentManager.MdiActiveDocument != null
		&& Application.DocumentManager.Count != 0)
		Helper.CmdLineMessage(str);
	else
		Helper.InfoMessageBox(str);
	Helper.StreamToRichTextControl(str);
catch (System.Exception ex)
	Helper.Message(ex);
Possible why it was working and then not working no? Should possible consider adding to avoid the error in the future.
Message 9 of 10
adn019LKFW
My problem is that Initialize() is not invoked after netload, and commands in this project are not registered, Editor.WriteMessage() is just an example added here.
Message 10 of 10
varshaauti27
@adn019LKFW
Remove
It should work as expected!
