Dimension In 3d Using VB.Net
NEP_perpetual
NEP_perpetual
I'm writing a .Net extension for AutoCAD and I've been unsucessful in trying to make dimensions in 3d (i.e. on the z axis).  Here is the code that I'm have to try to accomplish this:
Dim doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim db = doc.Database
Dim ed = doc.Editor
Using trx As Transaction = db.TransactionManager.StartTransaction()
	' Open the Block table for read
	Dim bt As BlockTable = TryCast(db.BlockTableId.GetObject(OpenMode.ForRead), BlockTable)
	' Open the Block table record Model space for write
	Dim acBlkTblRec As BlockTableRecord = trx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
	' Create the dimension
	Dim acRotDim As RotatedDimension = New RotatedDimension()
	acRotDim.SetDatabaseDefaults()
	acRotDim.XLine1Point = New Point3d(120, 120, 0)
	acRotDim.XLine2Point = New Point3d(120, 120, 120)
	acRotDim.DimLinePoint = New Point3d(140, 120, 0)
	' Add the new object to Model space and the transaction
	acBlkTblRec.AppendEntity(acRotDim)
	trx.AddNewlyCreatedDBObject(acRotDim, True)
	trx.Commit()
End Using
When this code is run the dimension is created and the extension line snaps are in the correct places.  However, the lines and text are stuck on the "ground" and it's shows a distance of 0.  How can I create the dimension so that it's on the right plane?
_gile
You also need to set the Rotation, Normal and Elevation properties.
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                var space = (BlockTableRecord)tr.GetObject(
                    SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite);
                var dim = new RotatedDimension();
                dim.SetDatabaseDefaults();
                dim.XLine1Point = new Point3d(120.0, 120.0, 0.0);
                dim.XLine2Point = new Point3d(120.0, 120.0, 120.0);
                dim.DimLinePoint = new Point3d(140.0, 120.0, 0.0);
dim.Rotation = Math.PI / 2.0; // 90° for vertical rotated dimension dim.Normal = new Vector3d(0.0, -1.0, 0.0); // parallel to XZ plane dim.Elevation = -120.0; // Elevation on the XZ plane space.AppendEntity(dim); tr.AddNewlyCreatedDBObject(dim, true); tr.Commit(); }
Gilles Chanteau
GileCAD
GitHub
NEP_perpetual
Thanks, that works perfectly!
