Dialog/Form design doesn't match
StormyC
StormyC
When using .NET8 / VS2022 and AutoCAD2025 the design for the form doesn't match with the form ultimately displayed in AutoCAD.  Any clues?
I have tried WPF and WinForms, both the same.
Accepted solutions (3)
ActivistInvestor
.NET 8 introduces breaking changes in Windows forms sizing/scaling behavior.
Have a look at this document.
DYH_
Prefer using WPF, layout and divide with Grid, and do not use mouse dragging to create interface elements.
StormyC
Interesting - thanks.  I did try to adjust some setting relating to DPI scaling but the issue appears to be:  I created a new WPF Form and the Form controls are present within AutoCAD and not in the designer so this pushes everything down causing the last button to be clipped.  If i add 40px to the bottom of the form it appears OK...
Ive used a fully defined grid now and added elements in .xaml as suggested.  Seems to be working ok.
Thanks both for you inputs.
StormyC
Finally found the fix for my particular issue it was a property on the form - this was "Font".  Setting it to None makes the forms appear correct.
