Determine if document contains 3D elements
Is there an API method or property that I can use to determine if an AutoCAD document has 3D elements?  I tried looking for a flag when the message 'Loading Modeler DLLs' is shown as that seems to be a fairly reliable indicator, but found nothing.  I'd prefer not to traverse the database elements, if possible.
Using:
AutoCAD 2011
Visual Studio 2008 SP1
Project is in VB.NET Using .NET 3.5
Thanks!
Due to the deafening sound of crickets I've heard from this post, I'd thought I'd supply the solution I came up with.  This may not be the best way, but it seems to work reliably.
Dim oARX_Objects As Object
            Dim sARX_Objects() As String
            Dim bDocIs3D As Boolean = False
            'Get all loaded modules. Returns a single object that hides an array of strings
            oARX_Objects = AcadMan.ListArx()
            'Convert the object into a usable  string array
            sARX_Objects = CType(oARX_Objects, String())
            'Search for key DLL's that indicate a 3D document.
            For Each sARX_Name As String In sARX_Objects
                If sARX_Name.ToLower = "aecmodeler60.dbx" Then
                    bDocIs3D = True
                    Exit For
                If sARX_Name.ToLower = "aecsolidmodeler.dbx" Then
                    bDocIs3D = True
                    Exit For
                If sARX_Name.ToLower = "acsceneoe.dbx" Then
                    bDocIs3D = True
                    Exit For
            Next
