Depth of Solid3D
Depth of Solid3D
eirij
Depth of Solid3D
eirij
Is there any way to find the Depth of a Solid3D?
Thanks!
_gile
You should clarify what you mean with: "the Depth of a Solid3D"?
If you mean the vertical ditance between the bottom of the solid to its top, you can use the solid extents (bounding box).
        public static double GetSolid3dDepth(Solid3d solid)
            var extents = solid.GeometricExtents;
            return extents.MaxPoint.Z - extents.MinPoint.X
Gilles Chanteau
GileCAD
GitHub
eirij
Thank you for your idea!
Actually i would like to find the thickness of the solid3d. Attach you can also find an example with thickness of 0.12m. I tried with Geometric Extents but the value is not that accurate.
The other way could be AverageThickness = Volume / Area of one side. Do you know how to get the AREA of the upper or lower surface of this solid3d?
Can you please have a look.
_gile
Here's a way using the Brep (Boundary Representation) API. You have to reference the acdbmgdbrep.dll assembly.
        public static double GetAverageThickness(Solid3d solid)
            double volume = solid.MassProperties.Volume;
            using (var brep = new Brep(solid))
                double area = brep.Faces
                    .Select(f => f.GetArea())
                    .Aggregate(Math.Max);
                return volume / area;
Gilles Chanteau
GileCAD
GitHub
