Delete ObjectData Record from Palette
Sgear
Sgear
Hi
I am try to Delete Objectdata record from Palette ToolStrip Button but I get error and Autocad crash
Can anyone help me with this Please, Thanks
Sgear
Get Object Handle from Listview
        HandletoObjectID(Listv.SelectedItems.Item(0).SubItems(0).Text)
	    Public Function HandletoObjectID(ByVal Hndl As String) As ObjectId
        Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
        Dim trans As Transaction = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction
        Dim db As Database = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database
        Try
            Dim strHand As [String] = Hndl.ToString()
            Dim ln As Long = Convert.ToInt64(strHand, 16)
            Dim hand As New Handle(ln)
            Dim id As ObjectId = db.GetObjectId(False, hand, 0)
              Delete_record(id)
        Catch ex As System.Exception
            Return Nothing
        End Try
    End Function
    Public Sub Delete_record(stid As ObjectId)
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Using doclock As DocumentLock = doc.LockDocument
            Using tr
                Try
                    Dim odTables As Autodesk.Gis.Map.ObjectData.Tables
                    odTables = HostMapApplicationServices.Application.ActiveProject.ODTables
                    Dim dbObj = tr.GetObject(stid, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
                    Dim myTable As Autodesk.Gis.Map.ObjectData.Table = odTables("Table_name")
                    Using recs As Records = myTable.GetObjectTableRecords(0, dbObj, Constants.OpenMode.OpenForWrite, True)
                        Dim ie As IEnumerator = recs.GetEnumerator()
                        Do While ie.MoveNext()
                            recs.RemoveRecord()
                        Loop
                    End Using
                    tr.Commit()
                    ed.WriteMessage(ex.ToString & vbCr)
                    MsgBox(ex.ToString)
                End Try
            End Using
        End Using
    End Sub
Sgear
Finish to fix this
this URL help we with this
http://forums.autodesk.com/t5/net/wblock-crashing-in-net/td-p/3704648
        Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = acDoc.Database
        Dim acTransMgr As Autodesk.AutoCAD.DatabaseServices.TransactionManager
        acTransMgr = db.TransactionManager
