Delete Layout using c#
lvthunder
lvthunder
I have around a thousand files I need to change.  I update the titleblock and that is working fine.  I am trying to delete the Layout called Layout2, but it doesn't work.  This is the part of the code I'm using.  I don't have the drawing open in the editor because it saves so much time.  Does anyone know why it's not doing anything?
  public void PTDrawing(Database currentDb, MainForm control, string sheetName, string sheetType, Microsoft.Office.Interop.Excel.Worksheet tbExcel)
      using (Transaction acTrans = currentDb.TransactionManager.StartTransaction())
 LayoutManager.Current.DeleteLayout("Layout2");
    acTrans.Commit();
ActivistInvestor
See if this works:
   Database prevWorkingDb = HostApplicationServices.WorkingDatabase;
   HostApplicationServices.WorkingDatabase = currentDb;
   try
   finally
      HostApplicationServices.WorkingDatabase = prevWorkingDb;
ActivistInvestor
You should also get rid of the Transaction because I don't think it's needed when calling DeleteLayout(), and could be the cause of the problem.
lvthunder
Thanks that worked.
