DatePicker in Pallette Keeps closing
Message 1 of 8
Hi
I have got a pallet that I am showing in AutoCAD
I have created it as a custom control and then loaded it up when a command is run
the Problem i have got is that there is a datetimepicker in it and then i go to select a date from the dropdown it opens and then as soon as i go to move my mouse over it it then closes again
does anyone know a way to fix this ?
Replies (7)
Message 2 of 8
_gile
Difficult to diagnose without seeing any code...
this works for me:
In the XAML:
<TextBlock Grid.Row="0" Margin="10" Text="{Binding Date, StringFormat=dd/MM/yyyy}" />
<DatePicker Grid.Row="1" Margin="10" SelectedDate="{Binding Date}" />
In the class set as DataContext (which implements INotifyPropertyChanged)
DateTime date;
public DateTime Date
    get { return date; }
    set { date = value; RaisePropertyChanged("date"); }
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
ActivistInvestor
@Anonymous wrote:
Hi
With WinForms controls, this is not a simple problem to solve.
However, I've had to deal with this quite a bit in the past, so below is one of my custom WinForms controls that solves the problem.
using System;
using System.Runtime.InteropServices;
using System.Windows.Forms;
namespace AcadControlLibrary
   /// <summary>
   /// A specialization of System.Windows.Forms.DateTimePicker
   /// that can be used on a modeless floating window (such as
   /// a PaletteSet or a Form that is shown modelessly), which
   /// corrects the problem of AutoCAD stealing the input focus
   /// from popup windows.
   /// Use this class in lieu of System.Windows.Forms.DateTimePicker.
   /// </summary>
   public class AcDateTimePicker : DateTimePicker
      KeepFocusHook hook = null;
      protected override void OnDropDown(EventArgs eventargs)
         if(!DesignMode)
            IntPtr hwnd = GetDropDownWindow();
            if(hwnd != IntPtr.Zero)
               hook = new KeepFocusHook(hwnd);
         base.OnDropDown(eventargs);
      protected override void OnCloseUp(EventArgs eventargs)
         if(hook != null && !DesignMode)
            hook.ReleaseHandle();
            hook = null;
         base.OnCloseUp(eventargs);
      class EnumChildren
         public IntPtr hwndFound = IntPtr.Zero;
         public bool enumChildren(IntPtr hwnd, IntPtr lparam)
            this.hwndFound = hwnd;
            return true;
         public delegate bool EnumChildrenCallback(IntPtr hwnd, IntPtr lParam);
      class KeepFocusHook : NativeWindow
         public KeepFocusHook(IntPtr handle)
            base.AssignHandle(handle);
         const int WM_ACADKEEPFOCUS = 0x7101;
         protected override void WndProc(ref Message m)
            if(m.Msg == WM_ACADKEEPFOCUS)
               m.Result = new IntPtr(1);
            else
               base.WndProc(ref m);
      IntPtr GetDropDownWindow()
         EnumChildren enumChildren = new EnumChildren();
         EnumChildren.EnumChildrenCallback func = new EnumChildren.EnumChildrenCallback(enumChildren.enumChildren);
         EnumChildWindows(new HandleRef(this, base.Handle), func, new HandleRef(null, IntPtr.Zero));
         return enumChildren.hwndFound;
      [DllImport("user32.dll", ExactSpelling = true)]
      static extern bool EnumChildWindows(HandleRef hwndParent, EnumChildren.EnumChildrenCallback lpEnumFunc, HandleRef lParam);
Message 4 of 8
Sorry for the late reply thanks for the code but its not working for me i am still having the same problem
I have changed the datetimepickers on the form the be the AcDateTimePicker but it still closes when you go to move your mouse over it
Message 5 of 8
Should the below bit of code be returning somthing ?
the below is what I'm getting when I run it in debug it returns 0x0000000000000000
Message 6 of 8
ActivistInvestor
The code I posted works for me without any problem.
I created a new UserControl, added an AcDateTimePicker to it, and then added the UserControl to a PaletteSet, and when I show the PaletteSet and click on the dropdown button on the DateTimePicker, the dropdown window appears and I can use the mouse to pick a date.
So, there must be something else happening on your end because I'm confident that it works, and I have many other custom controls with dropdown windows that I also use that same code with, and they also work.
What I can tell you is that it will not work in the debugger with a breakpoint set to stop when the dropdown button is clicked, because that will bring the debugger into the foreground, which will cancel the display of the popup window (and in that case, the result of GetDropDownWindow() will be IntPtr.Zero).
Did you try running the code outside of the debugger?
Message 7 of 8
Hi
Yes tried outside of debug and get the same issue
Tried also writing the editor and was getting the same result 0 being returned
Not sure if that would take the focus away ?
Message 8 of 8
ActivistInvestor
@Anonymous wrote:
Hi
Something else is not right on your end.
Please first confirm that you haven't made any changes to the above code, and what language are you using (VB or C#) ?  What AutoCAD release are you using, and what version of Windows are you using?
The only other way to get to the bottom of it, is to create a new ClassLibrary project, add the code I posted above, add a new UserControl to the project and drop an AcDateTimePicker control on it, then create a new PaletteSet and add the new UserControl to the PaletteSet, and compile and run the code, and see if it works.
