I am looking for a tested and safe way to open all drawings in turn in a project and cycle through them using the .net API. If I use the standard OPEN command, I am running into project integrity issues (Project may eject the drawing for no apparent reason) .
I have seen Autodesk.ProcessPower.ProjectManagerUI class suggested but can't seem to see any documentation for it anywhere.
I am limited to Plant3D 2019.
Specifically for now, I need to run PLANTAUDIT on all drawings so if there is an alternative approach, that would be appreciated as well.
Already posted on the plant forum. Just seeing if there is any more input from here.
