Custom Objects With .NET
Message 1 of 13
Hi all, I will better explain my question with a concrete simple example.
Let's say I want to build a command 2CIRCLE in .NET which would create two concentric circles where the inner one's radius is half of the outer one's radius.
I can see how to create this command, but what I cannot see at the moment is how to edit it later on. If someone selects it later on by clicking on either of the circles:
  1. both circles (the whole custom object) should be selected.
  2. editing an inner circle's radius (with the mouse) should be allowed but it should always affect the outer circle as the outer circle's radius should always be kept at double inner circle's radius length.
Is this possible with .NET or it has to be done with C++?
Thanks very much.
Replies (12)
Message 2 of 13
_gile
You cannot create custom object with the .NET API but you can use the Overrule API.
Here's a little example.
using Autodesk.AutoCAD.GraphicsInterface;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
namespace CircleOverrruleSample
    class CircleOverrule : DrawableOverrule
        public static string RegAppName => "Gile_ConcentricCircles";
        public CircleOverrule()
            AddOverrule(GetClass(typeof(AcDb.Circle)), this, true);
            SetXDataFilter(RegAppName);
            Overruling = true;
        public override bool WorldDraw(Drawable drawable, WorldDraw wd)
            var circle = (AcDb.Circle)drawable;
            wd.Geometry.Circle(circle.Center, circle.Radius, circle.Normal);
            wd.Geometry.Circle(circle.Center, circle.Radius / 2.0, circle.Normal);
            return true;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
    class CircleJig : EntityJig
        Circle circle;
        double radius;
        public CircleJig(Circle circle) : base(circle)
            this.circle = circle;
            radius = circle.Radius;
        protected override SamplerStatus Sampler(JigPrompts prompts)
            var options = new JigPromptDistanceOptions("\nSpecify the radius; ");
            options.BasePoint = circle.Center;
            options.UseBasePoint = true;
            options.UserInputControls =
                UserInputControls.Accept3dCoordinates |
                UserInputControls.NoNegativeResponseAccepted |
                UserInputControls.NoZeroResponseAccepted;
            var result = prompts.AcquireDistance(options);
            if (result.Value == radius)
                return SamplerStatus.NoChange;
            radius = result.Value;
            return SamplerStatus.OK;
        protected override bool Update()
            circle.Radius = radius;
            return true;
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Core.Application;
    public class Initialization : IExtensionApplication
        DocumentCollection docs = AcAp.DocumentManager;
        static CircleOverrule overrule;
        public void Initialize()
            overrule = new CircleOverrule();
            AcAp.Idle += OnIdle;
        private void OnIdle(object sender, EventArgs e)
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            if (doc != null)
                AcAp.Idle -= OnIdle;
                doc.Editor.WriteMessage("\nCircleOverrruleSample loaded.\n");
        public void Terminate()
using Autodesk.AutoCAD.Geometry;
[assembly: CommandClass(typeof(CircleOverrruleSample.Commands))]
    public class Commands
        [CommandMethod("2CIRCLE")]
        public static void TwoCircleCommand()
            var db = doc.Database;
            var ed = doc.Editor;
            var ppr = ed.GetPoint("\nSpecify the center; ");
            if (ppr.Status == PromptStatus.OK)
                using (var tr = db.TransactionManager.StartTransaction())
                    var cSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    var circle = new Circle(ppr.Value, Vector3d.ZAxis, 1.0);
                    cSpace.AppendEntity(circle);
                    tr.AddNewlyCreatedDBObject(circle, true);
                    using (var data = new ResultBuffer(
                    new TypedValue(1001, CircleOverrule.RegAppName),
                    new TypedValue(1000, "Dummy text")))
                        AddXdata(circle, data);
                    var jig = new CircleJig(circle);
                    var pr = ed.Drag(jig);
                    if (pr.Status != PromptStatus.OK)
                        circle.Erase();
                        tr.Commit();
        private static void AddXdata(DBObject dbObj, ResultBuffer data)
            var db = dbObj.Database;
            var tr = db.TransactionManager.TopTransaction;
            var regAppName = (string)data.AsArray()[0].Value;
            var regAppTable = (RegAppTable)tr.GetObject(db.RegAppTableId, OpenMode.ForRead);
            if (!regAppTable.Has(regAppName))
                var regApp = new RegAppTableRecord() { Name = regAppName };
                regAppTable.UpgradeOpen();
                regAppTable.Add(regApp);
                tr.AddNewlyCreatedDBObject(regApp, true);
            dbObj.XData = data;
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 13
Hey Gile!
Can you send me your soluttion file? I am very grateful for that.
My email is: hungspkt123@gmail.com
Thanks you!
Message 4 of 13
_gile
@Anonymous
I do not understand why you want a solution which you'll probably have to edit to match your computer architecture rather than build it by yourself with the source code I provided.
Anyway, I attached the whole solution for Visual Studio 2017.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 13
Kélcyo
Starting from the base of your code, it is possible to create a 3D polyline with 3 vertices that represents 2 tangents and the central point a point of inflection. And an arc that has its start and end point limited to displacements on top of the tangents? That is, the grips of the 3D polyline, adjust the arc with the beginning and end always touching the tangents, while the grips of the arc, only move on top of the tangent sizing its length...
Message 6 of 13
_gile
I'm sorry, I do not understand what you describe. May be a drawing should be more descriptive.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 13
Kélcyo
I believe this illustration is understandable. The Tangents of the 3D Polyline are the rails limiting the movement of the Arc's points. The grips (points of the 3D Polyline) are free to change and after any adjustment, the Arc is automatically adjusted to the new location, maintaining its previous length.
Message 8 of 13
_gile
You do not provide enough informations.
How are the points of tangency between the arc and the polyline segments determined?
Is the arc radius fixed? If so, what happens if a polyline segment is too short?
Gilles Chanteau
GileCAD
GitHub
Message 9 of 13
ActivistInvestor
The fact that you show an oblique view of a two-dimensional drawing with text is enough for me to head for the nearest exit.
Message 10 of 13
Kélcyo
The three points are obtained by 3 vertices of a polyline3d, while the arc has a fixed length, which is adjusted the radius, according to the angle between the two 3D tangents. However, if one of the segments of the polyline3d that form the tangents, is smaller than the tangent allowed by the radius that determines the fixed length, the arc is automatically reset to have the point with a limit slightly smaller than the tangent on its side, so that it does not occur from the initial or end point of the polyline3d coincide with the same of the arc.
Message 11 of 13
Kélcyo
It is not about objects in 2 dimensions, the oblique way of representing was only for a better description of the items involved, the polyline is 3d, and the arc touches its tangents
Message 12 of 13
Kélcyo
I will try to give a more detailed explanation about my construction of objects
1-we obtain two 3d points that have their claws shown to be changed
2-we draw an imaginary line that connects the two points, this imaginary line is the position track of another 3d point which has limits at the beginning and end so as not to coincide with the previous points
3- the tangent is formed and the point that moves first on the track would be the starting or ending point of the arc
4- repeat the process, making one of the points of the second process were coincident and formed an inflection point, we would now have 3 points that form two imaginary lines where they move along them, two points that are the initial and final points of an arc with fixed length and variable radius
5-by moving one of the points of the arc, the other also moves on the other tangent symmetrically, changing its length and blocking the limits on both sides of the tangents
Message 13 of 13
_gile
I'm sorry, it's still confusing for me.
You should start another topic trying to describe precisely what are the input data (e.g., a 3d polyline and the constraints of the arc with respect to the polyline).
Gilles Chanteau
GileCAD
GitHub
