Creating multi-line Mtext
I'm having trouble getting an mtext entity with multiple lines of text. I've tried adding vbCrLf, vbLf, vbCr, \P, \n to the Text property but the end result is always a single, wrapping line of text in the mtext entity.
Anyone have an idea what I'm missing?
Thanks in advance.
i use vbcrlf all the time with mText, and i haven't had any issues. perhaps you could provide the code in question.
I can't put all the code here due to privacy policies in my company but I have posted the mtext creation bit below...
...code above...
Dim PtA As Geometry.Point3d = oEd.GetPoint(vbCrLf & vbTab & "Select Note Insertion Point: ").Value
Dim strText As String = cboSeries.Text & vbCrLf & cboStyle.Text & vbCrLf & cboType.Text & vbCrLf & cboExtra.Text
Dim oMtext As New MText
With oMtext
.Width = 300.0
.TextHeight = 8.0
.Location = PtA
.Attachment = AttachmentPoint.MiddleCenter
.SetContentsRtf(strText)
End With
oBtr.AppendEntity(oMtext)
oTrans.AddNewlyCreatedDBObject(oMtext, True)
End If
...code below...
Hopefully it's something stupid I'm overlooking.
Sounds like a crappy company 🙂
set
.setContentsRtf(strText)
to
.Contents = strText
-Mark Pendergraft
>> .Width = 300.0
Change that number to an smaller value ie 4.0.... and see what happens.
Changing to .Contents = strText did the trick!
Thanks 🙂
